Base XXLT9
S-Voice S5 Added
More tweaks of battery life and performance
Forest-HelloWorld-Make-II-V1.6.4 (the BIG difference of the ROM, will make your N7000 too much faster!
4 way reboot options
SMS recipient limit is set to 200.
Auto convert SMS to MMS is disabled.
Permanent disabling of SMS, MMS, and Email log in call log
SMS per hour sending limit is increased to 1000 SMS per hour
Call record is enabled.
Ascending ringtone is disabled.
Smart Rotation is enabled.
Lockscreen Shortcuts is enabled
Lockscreen information ticker is enabled
Fully functioning airview for SecGallery and VideoPlayer and partially for SPlanner.
Multiwindow for unlimited apps.
Shutter camera sound on/off option.
Camera focusing sound is disabled.
All camera battery restrictions are removed
Ink effect color changer
Build.prop and init.d tweaks and optimizations
Download
https://docs.google.com/file/d/0Bxzc...BacV84bXc/edit
INSTALLAZIONE
1) andare in CWM recovery
2) wipe cache, wipe dalvik wipe factory reset (install new rom)
3) flash zip rom file
4) reboot
Se avete problemi o alcuni errori nel riavvio della rom rientrate in CWM recovery rieseguite i wipes e riflashate la ROM
Thread XDA
[ROM] *** JonROM RESSURRECTION V16 XXLT9 *** (( CLEAN, FAST, SMOOTH )) [07.04.2014] - xda-developers
