riporto la conversazione avuta col senior member di xda e tester per la jetmod shout_down
"Originally Posted by migaia
Hi shut_down,
I ask to u because I saw that u just install the cocore kernel.
I would like to install CoCore kernel too. I have just Jetmod 3.2.2. Must I flash the Cocore kernel 3.7.zip by TWRP ? Some wipe is required ??? There's some trick to know ? And what are the performances of Cocore kernel respect to thunderzap ?
thanku and sorry for my english
Michele
That is the simplest way to change kernel. If not you will have to unpack and do it via Odin or cmd in windows. You can wipe cache, dalvik in TWRP after installing kernel. When you install it open app called NO-frills CPU. Set Governor to PegasusQ, and I/O Schaduler to SIO. Thay manage how CPU reacts, and thay are best balance between battery and performance. I do not know about performance difference, but CoCore have more tweaks than ThunderZAP. And I use it since beggining almost."
Ricordo che flashando questo kernel non sarà possibile utilizzare il power menu per riavviare o entrare in modalità recovery direttamente da esso. Pena il continuo riavviarsi del terminale. Ma bisognerà utilizzare il solito metodo dei tasti vol+/menu/poweroff premuti contemporaneamente,
Per quanto riguarda il settaggio di No frill-Cpu, ho avuto problemi di riavviocol governor PegasusQ mentre settando quest'ultimo su Ondemand, non riscontrato problemi.
