Da ieri 05/06/2012 è presente la nuova build38.
Ultima modifica di Partake; 06-06-12 alle 11:42
Questi.....
Build 38 Changelog
reverted tablet nav bar button padding change (back to stock ics padding now)
fix SMS/BT crash bug when no msgs exist
reworked lockscreen music layout to be cleaner
fix ugly gradient on dark holo background
added AOKP Tips widget
added statusbar autohide for tablets (for apps that need full screen)
added support for more lockscreen targets (2-8 options, your choice)
cleaned up octo lockscreen layout
fixed certain FCs with RC related to weather
Mms: fixed stripping certain Polish characters
decreased size of custom lockscreen apps to match other icons
statusbar brightness enabled by default after you wipe (sliding thumb across statusbar to change brightness)
added statusbar notification counter (RC > Statusbar General > Notification Counter)
new AOKP boot animation from @rascarlo
Out of range Bluetooth devices won't show up anymore in Settings
Browser: added option to close all other tabs (besides current)
Fixed data toggle
Removed requirement to reboot when toggling keyboard switcher (IME switcher) in statusbar
added nav bar widgets (to enable, go to nav bar settings > add toggle widgets as one of your nav bar actions/ long press actions, then add widgets -- be sure to add at least 2 for best experience)
as always, tons of fixes for devices and other backend fixes!
Partake (06-06-12)
scusate l'ignoranza ma da cosa bisogna partire per installare questa rom? io per esempio ho la xxkb3
Ciao, non mi sono voluto mai addentrare in rom spinte come questa, presumo. Sopratutto, il cell deve funzionare in ogni sua feature disponibile, quindi, rispetto alla rom che vedete in firma (la uso da parecchio, è una bomba in tutto) consigliate questa?
Ogni tanto faccio una capatina qui per capire se cambiare rom o tenermi stretta la mia dopo mesi di prove varie...
Pino Mango/Daniele sempre nel cuore
Se vuoi "tutto" funzionante allora questa rom non fa ancora per te...... rimangono alcune cose da sistemare tipo la registrazione dei video e la codifica hardware, poi per la stabilità è favolosa e per altre cose anche molto performante.... se no fatti un bel nandroid backup della tua rom e provi questa e al limite se non sei soddisfatto torni indietro!!!
si manca la registrazione dei video e non c'è l'accelerazione hw completa
vurrut ha introdotto con la b38 anche l'openmax, è un'accelerazione per contenuti multimediali
io ho visto che youtube, che non mi andava con la release predente, ora va in HQ, piccoli lag ogni tanto ma usabilissimo
Device :
LG Nexus 5X bianco
Nexus 5 16 gb
Ok, giro alla larga. Per quello che serve a me, twz puro + power menu + batteria e stabilità come da stock, questa che uso ora è super. Youtube in hd mi va sempre perfetto per esempio.
Cmq stufo di aspettare un ics vero, vendo il cell e cambio...
Inviato dal mio GT-I9003 usando Tapatalk
la stabilità di queste rom è perfetta. se l'hw composer fosse completo funzionerebbero meglio di gb perchè hanno vari bugfix
la rom gb dell'i9003 è un po buggata
Device :
LG Nexus 5X bianco
Nexus 5 16 gb
ecco qui il quadrant
il quadrant per me è più metro di ottimizzazione della rom che delle reali impostazioni, comunque siamo ancora leggermente sotto a GB ma di poco, ora sto provando altre cosette...
c'è però più variazione tra i bench
Device :
LG Nexus 5X bianco
Nexus 5 16 gb
