Utente del giorno: diavolo78 con ben 49 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: Sfattucci con ben 220 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Sfattucci con ben 1226 Thanks ricevuti nell'ultimo mese
Pagina 3 di 5 primaprima 12345 ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 47
[ROM][i9003][OTA] ~⌘ EHNDROIX II 12.12.x ⌘~
  1. #21
    Androidiano L'avatar di carwi
    rende
    Samsung Galaxy SII
    Thanks
    l'ho provata, ancora non è ottimale nell'uso. come si torna ad ics CM9?
    SONY XPERIA NEO V Xperia Ultimate HD ICS 4.0.4 OC kernel 1.6Ghz
    SE TI SONO D'AIUTO MI BASTA UN THANKS
    Thanks
    Quote Originariamente inviato da chievo93 Visualizza il messaggio
    Welcome to the world of the EHNDROIX II !
    EHNDROIX II is a ROM based on CyanogenMod 10 created by Nitrox-developers Team. Edited and customized to the smallest details, was designed to provide users with an Jelly Bean user-friendly experience and is available for a wide range of terminals! !
    The ROM has been optimized to ensure maximum fluidity and at the same time good battery life and,
    thanks to Nitrox S, you will have the opportunity to stay up to date on the latest news and download launchers, themes "exclusive" mod and much more!
    Features
    ________________________
    • Based on CyanogenMod 10
    • New theme with new exclusive EhndroiX styles
    • Update the ROM directly from your device with integrated OTA Updater
    • Official bootanimation
    • Google Apps in Black Style
    • Xperia T Launcher
    • Flash Player Support
    • FM Radio Included
    • Send messages with exclusive EhndroiX app with a very attractive look and new features
    • Beats Audio equalizer with a unique
    • Don't you remember the title of a song? Now you can whistle or sing it and the device will give you all the information possible
    • Optimized for HD YouTube videos via 3G and Wi-Fi
    • Fantastic Official EhndroiX Wallpapers
    • GPS ultra running in all countries due to the automatic fix satellites
    • ROM in constant development (keep up to date thanks to date version)
    • Keep safe your data with Titanium Backup installed by default
    • ... and much more!
    Guide to proper installation
    Coming from a previous EHNDROIX II:
    • Download ROM
    • Wipe Cache
    • Wipe Dalvik / Cache
    • Flash EhndroiX
    • Restart
    Coming from EHNDROIX or CM7/CM9/CM10/AOKP/MIUI:
    • Download ROM
    • Wipe Data
    • Wipe Dalvik Cache
    • Flash EhndroiX
    • Restart
    Provengo dalla cyanogenmod 10 alpha 3, ho provato in tutti i modi ad installare questa mod perchè quando si apriva il telefono potevo solo abbassare la tendina delle notifiche, così ho provato ad installare anche le gapps, ma niente.. ora ho riprovato a reinstallare la cyanogenmod 10 alpha 3 ma il telefono non si apre più... auitatemi!!
  4. #23
    Thanks
    30
    ragazzi, ho già installato 2 volte la rom, ma non ci riesco.
    faccio tutto da zero, installo, riavvio, esce la scritta samsung galaxy...... poi si spegne, ricompare e fa questo all'infinito.
    dov' è che sbaglio?
  5. #24
    Androidiano VIP L'avatar di AlessandroXCV
    Dec 2009
    Nexus 7 ;Galaxy S+; Tattoo ...
    Thanks
    44
    Aspettate che tra poco rilascio la nuova release e flashate quella
    Il thanks è gradito
    Inviato dal mio Nexus 7 con Tapatalk 2
  6. Il seguente Utente ha ringraziato AlessandroXCV per il post:
    biberon (08-02-13)
  7. #25
    Androidiano L'avatar di chievo93
    i9003 cm10
    Thanks
    Reworked ROM
    Changed Kernel in Siri Kernel RC3 HotFix
    Change LCD Density ( Looks like Phablet UI )
    System Improvement
    Removed Photos Auto-Compression
    Better Fluidity
    Better Data Connection
    Better Wi-fi Signal
    Better GPS Connection
    Updated Default Apps
    Fixed some other mini bug
    Sync to lastest CyanogenMod sources
    And other...
  8. #26
    Provincia di Taranto
    Galaxy S GT-I9000 2.3.6 JVU
    Thanks
    Quote Originariamente inviato da AlessandroXCV Visualizza il messaggio
    Il thanks è gradito
    Beniiiissimo!!
    Comunque sia caro punzo77 purtroppo è errata la guida in prima pagina... non so se funzionerebbe lo stesso con la guida corretta, ma quella in prima pagina è errata.
    Ecco i passaggi corretti:
    Download ROM
    Download GAPPS con sfondo bianco (originali Google): oppure le GAPPS con sfondo nero (le GAPPS con colori invertiti)
    Wipe Cache Partition;
    Wipe Dalvik Cache;
    Flash EhndroiX II;
    Flasha questo Hotfix:
    Flash GAPPS;
    Riavviare e enjoy it!
    ciaoooo ovviamente non mi assumo nessuna responsabilità e tanto meno so se funziona davvero, so solo che questa è la procedura corretta
    Ultima modifica di Rikkardo92; 08-02-13 a 22:28
    Samsung Galaxy S GT-I9000
    - [FW] Jelly Bean 4.2.1 (CM10.1)
    - [ROM] Helly Bean 4.2-20120207
    - [RAM] 403 MB
    - [KERNEL] 3.0.56 Devil Kernel
    - [MODEM] I9000XXJW6
  9. #27
    Thanks
    Ma la 13.2.9 è disponibile???
  10. #28
    Thanks
    - [RAM] 403 MB
  11. #29
    Thanks
    Ok, ma nei commenti dice che ci sono molti bug... Provenendo da un Ehndroix semplice... Mi conviene?!!
  12. #30
    Thanks
    I commenti negativi sono giusti, per le vecchie versioni, è un Thread unico per ogni aggiornamento della Ehndroix 2, quindi non sappiamo se funziona bene, leggendo il ChangeLog direi di si, ma non si puo' sapere, io la proverei se avessi l'i9003, ma sappi che quei commenti sono vecchi
    - [RAM] 403 MB
  • Non puoi inserire repliche
