INCLUDES
*Full Framework
*Dock Launcher Pro
*New waiting cursor
*Settings
*my new analog clock
*icons set
ans much more!
INSTALLATION:::::::NEW METHOD::::::::100% secure!!!!!!!!!!!!
1 Download from the market Root Explorer
2 Run it and close abititing the super user access
3 Download my 3 rar and extract "Settings.apk", "framework-res.apk" and "twframework-res.apk" in your Galaxy
4 Open Root explorer, make sure you have select on the top "mounted as r/o" and copy settings.apk in system\app and framework-res.apk and twframework-res.apk in system\framework
5 Waiting for the reboot
6 Enjoy!
*For install my clock extract it in your galaxy and install it as a normal application
* The icons must be use with Better Cut or a similar application
* The dock png is for Launcher Pro
TESTED ON MY GALAXY S WITH JM5 ROM
Disclaimer
This product is free to use, but at your own risk. I take no responsibility for any conflict, fault, or damage caused by this appling morph theme. No warranties of any kind are given. I have tested my product and have not found any problems with it.
BUILD V1.0
DOWNLOAD
Multiupload.com - upload your files to multiple file hosting sites!
