Temo tu abbia una CWM configurata per la voodoo e non la Speedmod...
Nella nuova v.9 il lagfix č abilitato di default. Quindi se ce l'hai disabilitato verrā abilitato automaticamente.
Io avevo una 8.2 con speedmod k12P ma lagfix disabled.
Ho appena terminato l'installazione della versione italiana, ma riscontro i seguenti problemini:
1) Si dice che la ROM abilitā il lagfix automaticamente, questo accade per entrambi i kernel? Io ho installato lo speed mod, ma il lagfix non č attivo (verificato tramite menu della recovery)
2) Anche se ho selezioneto nell'applicazione per la configurazione le applicazioni di terze parti non le ha installate
3) Ho l'applicazione Superuser, ma il telefono sembra essere non ROOTATO
Qualche consiglio?!
Edit: Dal menu recovery ho installato busybox+su riusultato mi č sparito il market ed alcune applicazioni!!
HELP!
Ultima modifica di hamleto; 24-01-11 alle 15:26
darkm20 (24-01-11)
io riuscissi a capire il perchč di quel casino in CWM sarei + felice...
Running Mount script
Voodoo Lagfix was not detected
System Lagfix was not detected
mounting DATA as RFS
DATA is successfully mounted
mounting DBDATA as RFS
DBDATA is successfully mounted
Done Mount script
Running WIPE/NO-WIPE script
We are running on Darky's ROM
Forcing WIPE from SD-Card
Executing WIPE
/data/.mac.info was wiped
/data/.pcsync_stream was wiped
/data/.psm.info was wiped
/data/.usb_stream was wiped
/data/anr was wiped
/data/app/Ajax.apk was wiped
/data/app/Bobel.apk was wiped
/data/app/Cath.apk was wiped
/data/app/ITCKrist.apk.apk was wiped
/data/app/KatyBerry.apk was wiped
/data/app/Saginaw.apk was wiped
/data/app/Venus.apk was wiped
/data/app/adaptive.cogid-1.apk was wiped
/data/app/brush.apk was wiped
/data/app/bz.ktk.bubble-1.apk was wiped
/data/app/circular_battery_indicator.apk was wiped
/data/app/com.adobe.flashplayer-2.apk was wiped
/data/app/com.adobe.reader-1.apk was wiped
/data/app/com.ahn.widget.contactWidget-1.apk was wiped
/data/app/com.alienmanfc6.wheresmyandroid-2.apk was wiped
/data/app/com.android.vending-2.apk was wiped
/data/app/com.androidapps.spareparts.apk was wiped
/data/app/com.angryredplanet.android.rings_extended-1.apk was wiped
/data/app/com.appspot.swisscodemonkeys.apps-1.apk was wiped
/data/app/com.aurorasoftworks.quadrant.ui.standard-1.apk was wiped
/data/app/com.buzzbox.mob.android.news.corriere-1.apk was wiped
/data/app/com.chartcross.gpstest-1.apk was wiped
/data/app/com.codesector.maverick.lite-1.apk was wiped
/data/app/com.darkyrom.darkyconfig-1.apk was wiped
/data/app/com.dataviz.docstogo-1.apk was wiped
/data/app/com.dropbox.android-1.apk was wiped
/data/app/com.dynotes.miniinfo-1.apk was wiped
/data/app/com.ebproductions.android.launcher-2.apk was wiped
/data/app/com.electricsheep.asi-2.apk was wiped
/data/app/com.estrongs.android.pop-1.apk was wiped
/data/app/com.evernote-1.apk was wiped
/data/app/com.extendedcontrols-1.apk was wiped
/data/app/com.facebook.katana-1.apk was wiped
/data/app/com.fede.launcher-2.apk was wiped
/data/app/com.gau.go.launcherex-1.apk was wiped
/data/app/com.gau.golauncherex.notification-1.apk was wiped
/data/app/com.google.android.apps.unveil-2.apk was wiped
/data/app/com.google.android.googlequicksearchbox-1.apk was wiped
/data/app/com.google.android.stardroid-1.apk was wiped
/data/app/com.google.android.voicesearch-1.apk was wiped
/data/app/com.google.maps.apk was wiped
/data/app/com.google.youtube.apk was wiped
/data/app/com.google.zxing.client.android-2.apk was wiped
/data/app/com.haxor-2.apk was wiped
/data/app/com.iceberg.CallSync-1.apk was wiped
/data/app/com.iceberg.smssync-1.apk was wiped
/data/app/com.iconology.comics-2.apk was wiped
/data/app/com.imdb.mobile-1.apk was wiped
/data/app/com.inizz-1.apk was wiped
/data/app/com.intsig.camscanner-1.apk was wiped
/data/app/com.keramidas.TitaniumBackup-2.apk was wiped
/data/app/com.koushikdutta.rommanager-1.apk was wiped
/data/app/com.layar-2.apk was wiped
/data/app/com.levelup.beautifulwidgets-1.apk was wiped
/data/app/com.levelup.bw.forecast-1.apk was wiped
/data/app/com.lookout-1.apk was wiped
/data/app/com.melodis.midomiMusicIdentifier.freemium-2.apk was wiped
/data/app/com.monotype.android.font.Abductionsmall.apk was wiped
/data/app/com.monotype.android.font.Buffy.apk was wiped
/data/app/com.monotype.android.font.Burton.apk was wiped
/data/app/com.monotype.android.font.Comforta.apk was wiped
/data/app/com.monotype.android.font.DS9.apk was wiped
/data/app/com.monotype.android.font.Darkness.apk was wiped
/data/app/com.monotype.android.font.Nuevastd.apk was wiped
/data/app/com.monotype.android.font.Segoe.apk was wiped
/data/app/com.monotype.android.font.akbar.apk was wiped
/data/app/com.monotype.android.font.argos.apk was wiped
/data/app/com.monotype.android.font.centurygothic.apk was wiped
/data/app/com.monotype.android.font.comicsans.apk was wiped
/data/app/com.monotype.android.font.copperplate.apk was wiped
/data/app/com.monotype.android.font.staravenue.apk was wiped
/data/app/com.quoord.tapatalkxda.activity-1.apk was wiped
/data/app/com.samsung.swift.app.kiesair-1.apk was wiped
/data/app/com.semicuda.typoclock-1.apk was wiped
/data/app/com.sgsinfo.apk was wiped
/data/app/com.sgstoolbox.apk was wiped
/data/app/com.siriusapplications.quickboot-1.apk was wiped
/data/app/com.skype.raider-1.apk was wiped
/data/app/com.speedsoftware.rootexplorer-2.apk was wiped
/data/app/com.teamviewer.teamviewer-1.apk was wiped
/data/app/com.twitter.android-2.apk was wiped
/data/app/com.type.android.font.facit.apk was wiped
/data/app/com.type.android.font.kievit.apk was wiped
/data/app/com.type.android.font.zegoe.apk was wiped
/data/app/com.waze-1.apk was wiped
/data/app/com.xrath.jmsn-1.apk was wiped
/data/app/courier.apk was wiped
/data/app/darkfactor.conanchat-1.apk was wiped
/data/app/de.Fr4gg0r.SGS.Tools-1.apk was wiped
/data/app/digital.apk was wiped
/data/app/eurofurence.font.apk was wiped
/data/app/gov.nasa.Spinoffs-1.apk was wiped
/data/app/illegal.apk was wiped
/data/app/it.medieval.blueftp-1.apk was wiped
/data/app/jackpal.androidterm-1.apk was wiped
/data/app/jp.co.bii.android.app.dskvzr-1.apk was wiped
/data/app/mobi.conduction.swipepad.android-2.apk was wiped
/data/app/neldar.bln.control.free-1.apk was wiped
/data/app/net.hubalek.android.gaugebattwidget-1.apk was wiped
/data/app/net.zedge.android-1.apk was wiped
/data/app/oldenglish.apk was wiped
/data/app/org.ajeje.credito3-1.apk was wiped
/data/app/org.gmote.client.android-1.apk was wiped
/data/app/org.projectvoodoo.app-1.apk was wiped
/data/app/org.tostada.android.ClearDefault-1.apk was wiped
/data/app/org.zeam-2.apk was wiped
/data/app/stericson.busybox-1.apk was wiped
/data/app/times.apk was wiped
/data/app/ymst.android.homeswitcherfroyo-1.apk was wiped
/data/backup was wiped
/data/dalvik-cache was wiped
/data/data was wiped
/data/dontpanic was wiped
/data/gps was wiped
/data/local was wiped
/data/log was wiped
/data/lost+found was wiped
/data/misc was NOT wiped
/data/property was wiped
/data/system was wiped
/data/tombstones was wiped
/data/user.log was wiped
/data/user.log.old was wiped
/data/wifi was wiped
/data/zipalign.log was wiped
/system/CSCFiles.txt was wiped
/system/CSCVersion.txt was wiped
/system/SW_Configuration.xml was wiped
/system/app was wiped
/system/bin was wiped
/system/build.prop was wiped
/system/cameradata was wiped
/system/csc was wiped
/system/default.prop was wiped
/system/etc was wiped
/system/firmware was wiped
/system/fonts was wiped
/system/framework was wiped
/system/lib was wiped
/system/media was wiped
/system/usr was wiped
/system/xbin was wiped
/cache/downloadfile-1.apk was wiped
/cache/downloadfile.apk was wiped
/cache/lost+found was wiped
/cache/recovery was wiped
/dbdata/databases was wiped
/dbdata/db-journal was wiped
/dbdata/system was wiped
/sdcard/Android/data was wiped
