bene sto aspettando rom cucinate *-*
ALLELUIA =)
ma e quello ufficiale Tedesco "krukko" ?
Alessio Piromallo
Web design e Programmatore Java, C++ e PHP
Scusate ma quale e' la differenza tra con bootloader e senza?
Ok, pare che il root sia lo stesso della release beta JV1
Here is how to root:
* Download CF-Root-XW_OXX_JV1 kernel from here : http://forum.xda-developers.com/show...08&postcount=3 (Remember to thank Chainfire for his excellent work!)
* Extract and flash the extracted tar file as PDA with no pit and no re-partition.
* Download the original kernel from here: Multiupload.com - upload your files to multiple file hosting sites!
* Done!
If you need to install Busybox then download it from Market....Good luck to all of you.
fonte: XDA
Max92 (26-03-11)
Max92 (26-03-11)
Io vado senza bootloader (meglio non rischiare troppo...) ma ecco direttamente da xda:
xda-developers - View Single Post - I9000xxjvk OFFICIAL GINGERBREAD FOR DOWNLOAD
Note 3 N9005 MIUI Wonitor
