- Based on Gingerbread 2.3.3 JVB + Modem JVO
- Chanfire CF-Root Kernel 3.1 JVB
- 329MB RAM
- Deodexed and Zipaligned
- Root + Busybox 1.19
- Simply Honey Honeycomb Theme (thx obsessionXYZ & explodingboy70)
- Overscroll Glow enabled!!
- OLD TV CRT Lock Screen Animation enabled! (enable all animations from settings)
- 5 LOCKSCREENS
- Fixed all Lockscreen Wallpapers (thx dhiru1602)
- CWM 3.0 Compatible Script (updater-script)(rewritten in 3.1)
- New BIOS Blue Bootanimation
- Arabic Support (via ADDON)
- Hebrew Support (via ADDON)
- NON INCREASING RINGTONE!!!
- Multi CSC JVK/JS1/JM1 (same as 2.7) with ITV, XEE, XEF and NEE included!!
- CWM App to easily use the Recovery
- Kernel Tweaks (use Tweak app)
- EXT4 Lagfix avaiable via "EXT4 App" (enable it from app)
- Optimised Zipaligning Script (thx to Darkyy)
- Memory Hack Script (thx to Darkyy)
- Hacked Hosts File (no more ads!!)
- A lot of build.prop tweaks! (optimised in 3.2)
- Fix for Multitouch and Maps
- Fix for SIP, Buttons Backlight and better 3D performances!
- Gallery totally fixed! (no battery drain, fixed lockscreen)
- SD Card Booster Script (thx Darkyy!)
- TouchWiz 4 Modded (5 icons dock + 5x4 app drawer) by me!
- Gingerbread 3D Launcher themed blue (by explodingboy70)
- Gingerbread Keyboard Themed with haptic feedback!
- Themed HoneyComb Market 2.3.6
- Hacked Camera (Battery + Shutter + Audio, thx to rafalense!)
- Hacked Browser (8 tabs + useragent + speed optimising)
- Fixed a lot of FCs
- A lot of themed apps!!! (new icons in 3.2)
- Auto-Rotation enabled in Dialer!
- Advanced Task Killer Froyo (latest update)
- SGS Tools
- Spare Parts Plus
- FasterFix
- App Widget Picker 1.4.4
- QuickBoot (modded & themed)
- Flash Player 10.2 pre-installed
- Latest Maps (5.4.0)
- Updated GMail App!!
- Animated Weather Widget (one of the best widget ever)
- Camcorder Shortcut
QUESTA ROM EFFETTUA UN WIPE/FACTORY RESET!!!
FARE UN BACKUP DELLE APPS PRIMA DI FLASHARE!!
ISTRUZIONI COMPLETE SULL'INSTALLAZIONE DELLA ROM (seguire alla lettera):
NON METTERE LA SPUNTA SU "PHONE EFS CLEAR"!!!!!!!!!!!!
BISOGNA AVERE INSTALLATA PRIMA LA ROM STOCK JVK CON IL BOOTLOADER PER PROCEDERE ALL'INSTALLAZIONE DELLA MIA ROM!!
FLASHARE UNA SIMPLY ROM WIPE:
- Scaricare lo SpeedMod Kernel K13D Odin Version (è un file .tar pronto per il flashing): Tourist In Paradise: Samsung Galaxy S: Download SpeedMod kernel
- Copiare il file .zip della ROM nella SDCARD interna del telefono
- Andare in Download Mode con il 3 button combo
- Aprire Odin, collegare il telefono, caricare come PDA il file .tar del Kernel SpeedMod K13D (NON SPUNTARE AUTO REBOOT!!!!) e flashare!
- Finito il flashing, togliere la batteria dal telefono e poi rimetterla.
- Andate direttamente in RECOVERY MODE con il 3 BUTTON COMBO
- Installate la ROM come sempre (install zip file from sdcard e poi yes)
- Dopo aver flashato la ROM, riavviare il cell (reboot phone now)
- Lasciarlo avviare (potrebbe metterci mooolto tempo essendo il primo boot)
- Godetevi la Simply Honey 3.x
FLASHARE UNA ROM SIMPLY NON WIPE:
SOLO SE AVETE GIÀ INSTALLATO UNA SIMPLY ROM 3.0 PRECEDENTEMENTE!!
- Copiate il file .zip della rom nella sdcard interna
- Usate l'app CWM MANAGER e selezionate "Install update.zip"
- Selezionare il file .zip della ROM
- Cliccare su "REBOOT"
- Attendete che abbia finito, si riavvierà da solo
- Ora avete installato una ROM Simply Non Wipe!
COME MUOVERSI NELLA RECOVERY:
- Volume su/giù -------> Muoversi su/giù
- Pulsante di accensione -------> Selezionare
COME CAMBIARE IL CSC:
- Nel tastierino numerico scrivere *#272*XXXXXXXXXXXX# dove la serie di X è il vostro IMEI (potete vederlo digitando *#06#)
- Selezionare il vostro CSC (ITV per l'Italia)
- Cliccate su INSTALL
- Dopo pochi secondi il telefono si riavvia ed effettua un Wipe
- Lasciare avviare il telefono
- Ora avete il nuovo CSC installato (ma dovete ripristinare tutte le app)
WIPE = Multiupload.com - upload your files to multiple file hosting sites!
NON WIPE = Multiupload.com - upload your files to multiple file hosting sites!
LA NON WIPE È SOLO PER CHI PROVIENE DA UNA ROM SIMPLY HONEY 3.X!!!!!!!!
