Peppegs (01-10-11)
Tigresiberiana (07-11-11)
monto la darky 10.2.2 jvq,posso montarci questo: Semaphore_kernel_JVS_1.7.5 ? grazie
snake24 (01-10-11),Tigresiberiana (07-11-11)
Un Grazie è ben gradito se ti sono stato utile
SamsungGalaxy S GT-I9000
ROM :[2.3.6]JW1 Servant V08
TEMA : N/D
MODEM : JVT
Kernel : Semaphore_Jvu-2.5.0
Firmware :- I9000XWJW1 - Gingerbread 2.3.6
Tutto android : http://droidland.altervista.org/
Io sono passato allo speedmod x il problema del tethering nin funzionante nemmeno con la 1.7.5
Inviato dal mio GT-I9000 usando Tapatalk
SmartPhone:
Samsung Galaxy S3 4.1.2 stock White
Tablet:
Samsung Galaxy Note 10.1 3G White
ma veramente ?
il tethering funge benissimo in tutte le versioni, devi solo abilitarlo
sveglia !!!!!!
In order to load various modules of the kernel copy the respective script from /res/scripts to /system/etc/init.d directory and give the script executable permissions. This is optional. It is needed only if you want to use this functionality. The scripts:
- enable_conservative (load conservative governor module)
- enable_cifs (load cifs module)
- enable_netfilter (load netfilter modules for firewall or WiFi, USB tethering)
- enable_tun (load tun module)
- enable_deadline (load the deadline I/O scheduler module)
- enable_binfmt_misc
- S05_enable_oc replaces enable_ocuv since 1.6.0 (enable overclocking)
Other scripts:
- enable_sm_cold script for SpeedMod cold preset
- enable_sm_warm script for SpeedMod warm preset
- enable_sm_neutral script for SpeedMod neutral preset (please note that this is enabled by default)
Ultima modifica di Mukuro; 04-10-11 alle 19:50
