Utente del giorno: Ivymike con ben 5 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: complicazio con ben 16 Thanks ricevuti negli ultimi sette giorni
Utente del mese: DreamReaper con ben 83 Thanks ricevuti nell'ultimo mese
Pagina 1 di 180 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 1797
[9.0][ASJG][G973/75F] ☼ CarHDMod V.8.0 ☼ [09/11/19]
    Lugo - RA
    Ringraziato 10,324 volte in 3,849 Posts
    CarHDMod V.8.0 - 09/11/19
    Based on G975FXXU3ASJG Firmware
    Android 9.0
    G975F-G973F Devices Supported
    #Mod#
    -Aroma Installer
    -Based on Firmware XXU3ASJG
    -Deodexed Apps
    -CSC Features
    -Tweaks in build.prop
    -1000 Extra Fonts
    -AppLock
    -Deleted high brightness warning
    -Deleted Volume warning
    -Bixby Button Remap
    -Added Camera Shutter Sound feature
    -Added Night Light toggle
    -Screen Recorder tile thanks to @Grouxho
    -Fixed Netflix
    -Secure Folder
    -and more
    #Rom Control#
    MODS
    -Skip Tracks on volume thanks to @Grouxho
    -USB plug/unplug wakeup
    -Long Press Back To Kill App
    -Bypass MicroSD/Sim2 tray lock
    -Battery Bar on NavigationBar
    -Buttons Only-Once/Always
    -TWLauncher mods
    SELECT IMAGE OR COLOR BG
    -Phone/IncallUI Customizable Background
    -Navigation Bar Customizable Background
    -Statusbar Customizable Background
    -AOD Customizable Background
    -Pulldown Customizable Background
    STATUSBAR
    -Settings statusbar clock (position, dimension, color)
    -3Minit battery
    -Stock battery
    -Virtual Buttons
    -Network Traffic
    -4G or LTE
    -Carrier Label
    -Adjust Brightness Swiping on Statusbar
    LOCKSCREEN
    -Next Alarm in lockscreen
    -Show/Hide Help and Charging Texts
    PULLDOWN
    -Notifications Customizable Background
    -Tiles Customizable Background
    -Tiles Shown from 3 to 10
    -Data Usage View options (color,position,font)
    -Analogic Clock
    -Device Info
    WIDGET
    -Settings Widgets
    -Widget in Pulldown
    -Widget in Lockscreen
    ANIMATIONS
    -Animation Scales 0.2x-0.25x-0.3x-0.4x-0.x5-0.6x-0.7x-0.8x-0.9x-1x-1.5x-2x-3x
    -Toast Animations
    INCALLUI PHOTO SIZE
    -From 420 to 460 dpi
    -From 370 to 411 dpi
    -From 330 to 360 dpi
    -Full screen
    -Circle Small
    Download and Changelog v.8.0 and Installation
    don't forget to thank this post
    Big thank to @ianmacd for TWRP and multidisabler
    Created 12/06/2019
    Last Updated 09/11/2019
    Ultima modifica di carotix; 11-11-19 alle 14:41
  2. I seguenti 10 Utenti hanno ringraziato carotix per il post:
    bluflight13 (12-06-19),danielionel (05-10-19),drago122 (12-06-19),hobin (12-06-19),iacomax (05-09-19),kartista75 (12-11-19),Q.dino (12-06-19),Trezor (04-08-19),usitaly (12-06-19),yuri76 (12-06-19)
    Lugo - RA
    CarHD Theme V.5.1
    it's in OTA/CARHD THEME/VERSIONS
    what's themed:
    -SystemUI
    -Accessibility
    -AODService_v40
    -Finder
    -SamsungCamera
    -SamsungContacts
    -SamsungDialer
    -SamsungGallery2018
    -SamsungInCallUI with mods and full screen
    -SamsungMessages_10.0
    -SecMyFiles2018
    -SecSettings
    -SMusic
    -TelephonyUI
    -framework
    -ClockPackage
    -SamsungCalendar
    -SamsungIMEv3.3
    -Weather_SEP10.1
    -CocktailBarService
    -SoundAlive
    Then to complete this theme you can install an apk Samsung Theme
    read this post
    Main Theme Part II
    what's themed:
    -EMail
    -SecMyFiles
    -SmartManager
    -Calculator
    -ThemeStore
    This zip will replace these deodexed apps in system
    you can restore to stock using CarHDMod
    every background is customizable from an only one folder (drawable-sw360dp-xxxhdpi-v13) in framework
    you can find the flashable framework to mod the theme , in OTA/CARHD THEME/MASTER FRAMEWORK
    use always the last framework from the last release
    Ultima modifica di carotix; 15-09-19 alle 09:34
  5. I seguenti 2 Utenti hanno ringraziato carotix per il post:
    bluflight13 (12-06-19),iacomax (05-09-19)
  6. #3
    Lugo - RA
    CarHDRom V.1.4 - 26/06/19
    Based on G975FXXU1ASE7 Firmware
    Android 9.0
    S10+ e S10 Devices Supported
    #Rom#
    -Aroma Installer
    -Based on Firmware G975FXXU1ASE7
    -G975F-G973F Support
    -Partially Deodexed
    -Magisk Manager
    -Stock Kernel
    -CSC Features
    -Wipes Options in Aroma Installer
    -30 Extra Fonts
    -BusyBox
    -AppLock
    -Adaware in Rom Control Apps
    -Deleted warning high brightness
    -and more
    #Rom Control#
    -Plug/Unplug USB Disable
    -Next Alarm in the Lockscreen
    -Statusbar , Navigation Bar Customizable Background
    -Virtual Buttons in statusbar
    -Open With options
    -Widget in Lockscreen Options
    -Navigation Bar Height
    -Transition Animations Scales 0.2x - 0.3x - 0.4x - 0.5x and more
    -Network Traffic
    -Custom statusbar clock (center on top or left side)
    -Option for 3Minit battery
    -4G to LTE on fly in Rom Control
    Download e Changelog v.1.3
    Installation:
    Dopo il flash della Rom ,
    non riavviare in system ma passare dallo spegnimento e riavviare con la combinazione dei 3 tasti
    per aver funzionante la fotocamera , occorre flashare la recovery stock , trovi lo zip in OTA/FILES FOR RECOVERY
    per riavere la TWRP patchata , occorre riflasharla da Odin e non serve altro
    Ultima modifica di carotix; 07-07-19 alle 15:21
  7. Il seguente Utente ha ringraziato carotix per il post:
  8. #4
    Lugo - RA
    Theme_True_Icons_V.11.apk
    it's a Samsung Theme ... You can download it from OTA/SAMSUNG THEMES
    Extra Icons Added
    HOW TO INSTALL:
    -Install a public Samsung Theme for icons before from the market and apply it
    -Install manually my theme
    -Using Root Explorer , open this folder data/overlays/jsonfiles/appiconjsonfiles/trialson cut the file carotix.true.icons.appiconpack.json and copy in userjson folder
    -Delete the folder data/overlays/preferences
    -Reboot
    -Open Samsung theme apk , then icons option , then apply my theme
    -Done
    Ultima modifica di carotix; 04-09-19 alle 11:37
  9. #5
    lissone(MI)
    HD Rom by Carotix
    Ringraziato 998 volte in 884 Posts
    Tanta roba Fra. Un grande
    Inviato dal mio SM-G955F utilizzando Tapatalk
  10. Il seguente Utente ha ringraziato yuri76 per il post:
    carotix (12-06-19)
  11. #6
    Androidiano VIP L'avatar di hobin
    Feb 2011
    GalaxyS10+G975F_HD_Rom_Carotix
    Ringraziato 124 volte in 107 Posts
    @Franco
    per riavere la TWRP patchata , occorre riflasharla da Odin e riflashare il multidisabler-g97x-1.1.zip
    Tutto questo si trova in ota???
  12. #7
    Lugo - RA
    Quote Originariamente inviato da hobin Visualizza il messaggio
    @Franco
    si si ... mi dicono che non occorre riflashare il multidisabler dopo aver riflashato la TWRP
  13. Il seguente Utente ha ringraziato carotix per il post:
    yuri76 (12-06-19)
  14. #8
    lissone(MI)
    HD Rom by Carotix
    Una cosa. La twrp va riflashata solo ogni volta che si flasha la rom?
  15. #9
    Lugo - RA
    Quote Originariamente inviato da yuri76 Visualizza il messaggio
    non servirà più flashare la recovery stock .... sono usciti i sorgenti del nuovo kernel , quindi la TWRP andrà sempre bene anche per la camera .... sto preparandola da flashare
    edit:
    questa è la TWRP nuova , patchata che ho reso flashabile da recovery
    con questa funziona anche la fotocamera .. la trovate anche in OTA/FILES FOR RECOVERY
    download
    Ultima modifica di carotix; 12-06-19 alle 17:46
  16. I seguenti 2 Utenti hanno ringraziato carotix per il post:
  17. #10
    Feb 2011
    edit:
    download
    La TWRP posso installarla prima e poi la rom.
