Originariamente inviato da folletto
Se non sbaglio il Kernel di Philz è stato aggiornato, voi avete lasciato quello che viene con la 16.1 o avete flashato l'ultimo?
New in v3.65 : PhilZ Touch v3.35 Recovery (CWM 6.0.1.9 based)
Completed ors implementation: added script started on boot, with same function as custom ors (simpler code than previous versions)
fixed ors-mount.sh support for phones without /emmc
goomanager support fixed for phones without /emmc
misc permissions fixes for recovery scripts
New in v3.62 : PhilZ Touch v3.34 Recovery (CWM 6.0.1.9 based)
Update to cwm 6.0.1.9
Add nandroid /preload backup & restore support
Add option to flash modem image from recovery
Fix Aroma File Manager path for devices without /emmc mount point
Fix: mount sdcards before launch aroma as some times we did not have access to other sdcard under aroma
Fix kerne/efs backup & restore for phones without /emmc
Optimized backup/restore status log for kernel/efs/modem: now showing true success/failure based on exit code/stderr from CAT
One ORS code is enough for custom and at boot scripts
Fixed ORS backup job log
Merge cm10 branch updates:
- Add support for doing a true ext4 format of /data on /data/media devices.
- Shorter confirmation menu if compiled as Philz Touch
Much more user friendly touch experience (3.0+)
