Pagina 204 di 219 primaprima ... 104154194202203204205206214 ... ultimoultimo
Visualizzazione dei risultati da 2,031 a 2,040 su 2185
Kernel]JEBOO v2.3a[XWLS8-LSD-LSE-LSJ-LSN-LSS & XXLSJ|MS1] JB i9100 [Light & Simple]
  1. #2031
    Senior Droid L'avatar di Cochinho90
    Lecce
    Samsung Galaxy S II
    Ringraziato 51 volte in 46 Posts
    Io il 2.2 l ho testato ma per poco.. avevo lo zzmove con i due scaling impostati a 1 ma davvero troppi riavvi... cambio kernel!!..
    Androidiano VIP L'avatar di federico54
    Ladispoli (RM)
    Galaxy S4 , S II
    Ringraziato 678 volte in 400 Posts
    Quote Originariamente inviato da N1m0Y Visualizza il messaggio
    Qui e qui trovi molte informazioni utili
    edit: ho trovato anche questo.....
    codice:
     *  drivers/cpufreq/cpufreq_zzmoove.c
     *  Copyright (C)  2001 Russell King
     *            (C)  2003 Venkatesh Pallipadi .
     *                      Jun Nakajima
     *            (C)  2009 Alexander Clouter
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
     * - ZZMoove Governor Changelog:        -
     * Version 0.1 - first release
     *- codebase latest smoove governor version from midnight kernel (https://github.com/mialwe/mngb/)
     *- modified frequency tables to match I9300 standard frequency range 200-1400 mhz
     *- added cpu hotplug functionality with strictly cpu switching
     *  (modifications partially taken from ktoonservative governor from
     *  ktoonsez KT747-JB kernel https://github.com/ktoonsez/KT747-JB)
     * Version 0.2 - improved
     *- added tuneables to be able to adjust values on early suspend (screen off) via sysfs instead
     *  of using only hardcoded defaults
     *- modified hotplug implementation to be able to tune threshold range per core indepentently
     *  and to be able to manually turn cores offline
     *  for this functions following new tuneables were indroduced:
     *  sampling_rate_sleep_multiplier -> sampling rate multiplier on early suspend (possible values 1 or 2, default: 2)
     *  up_threshold_sleep -> up threshold on early suspend (possible range from above "down_threshold_sleep" up to 100, default: 90)
     *  down_threshold_sleep -> down threshold on early suspend (possible range from 11 to "under up_threshold_sleep", default: 44)
     *  smooth_up_sleep -> smooth up scaling on early suspend (possible range from 1 to 100, default: 100)
     *  up_threshold_hotplug1 -> hotplug threshold for cpu1 (0 disable core1, possible range from "down_threshold" up to 100, default: 68)
     *  up_threshold_hotplug2 -> hotplug threshold for cpu2 (0 disable core2, possible range from "down_threshold" up to 100, default: 68)
     *  up_threshold_hotplug3 -> hotplug threshold for cpu3 (0 disable core3, possible range from "down_threshold" up to 100, default: 68)
     *  down_threshold_hotplug1 -> hotplug threshold for cpu1 (possible range from 11 to under "up_threshold", default: 55)
     *  down_threshold_hotplug2 -> hotplug threshold for cpu2 (possible range from 11 to under "up_threshold", default: 55)
     *  down_threshold_hotplug3 -> hotplug threshold for cpu3 (possible range from 11 to under "up_threshold", default: 55)
     * Version 0.3 - more improvements
     *- added tuneable "hotplug_sleep" to be able to turn cores offline only on early suspend (screen off) via sysfs
     *  possible values: 0 do not touch hotplug-settings on early suspend, values 1, 2 or 3 are equivalent to
     *  cores which should be online at early suspend
     *- modified scaling frequency table to match "overclock" freqencies to max 1600 mhz
     *- fixed black screen of dead problem in hotplug logic due to missing mutexing on 3-core and 2-core settings
     *- code cleaning and documentation
     * Version 0.4 - limits
     *- added "soft"-freqency-limit. the term "soft" means here that this is unfortuneately not a hard limit. a hard limit is only possible with
     *  cpufreq driver which is the freqency "giver" the governor is only the "consultant". So now the governor will scale up to only the given up
     *  limit on higher system load but if the cpufreq driver "wants" to go above that limit the freqency will go up there. u can see this for
     *  example with touchboost or wake up freqencies (1000 and 800 mhz) where the governor obviously will be "bypassed" by the cpufreq driver.
     *  but nevertheless this soft-limit will now reduce the use of freqencies higer than given limit and therefore it will reduce power consumption.
     *  for this function following new tuneables were indroduced:
     *  freq_limit_sleep -> limit freqency on early suspend (possible values 0 disable limit, 200-1600, default: 0)
     *  freq_limit -> limit freqency on awake (possible values 0 disable limit, 200-1600, default: 0)
     *- added scaling frequencies to frequency tables for a faster up/down scaling. This should bring more performance but on the other hand it
     *  can be of course a little bit more power consumptive.
     *  fast_scaling -> fast scaling on awake (possible values 0 disable or 1 enable, default: 0)
     *  fast_scaling_sleep (sysfs) -> fast scaling on early suspend (possible values 0 disable or 1 enable, default: 0)
     *- added tuneable "freq_step_sleep" for setting the freq step at early suspend (possible values same as freq_step 0 to 100, default 5)
     *- added DEF_FREQ_STEP and IGNORE_NICE definitions
     *- changed downscaling cpufreq relation to the "lower way"
     *- code/documentation cleaning
    Come potete notare il fast scaling se è impostato a 0 rimane disabilitato, mentre su 1 si abilita (proprio come avevo immaginato io )
    Si vede che ragiono in linguaggio macchina
    Stampato su carta Kodak.ciribiribì Kodak( ͡º ͜ʖ ͡º )
    .. Tu non stai bene hahahaha ma qst si sapeva già da tempo..... passiamo alle cose serie... Ho capito qualcosa delle guide.... Ma la maggior parte erano sul hotplug e su come quando è perke il 2nd core si attiva...a prestazioni non ho trovato nnt
    utilizza il tasto Thanks se ti sono stato d' aiuto ;D
  4. #2033
    Androidiano VIP L'avatar di N1m0Y
    originario del pianeta Vulcano
    Tricorder, GT-i9100, le Pro 3
    Ringraziato 3,811 volte in 2,605 Posts
    Quote Originariamente inviato da federico54 Visualizza il messaggio
    Prova così......
    Sampling rate = 50000
    Freq step = 100
    Inviato dal mio supermuletto :tank:
    Non risponderò in PM a richieste di aiuto sul modding. C'è il forum per questo, se usato correttamente.
    Se ti sono stato d'aiuto usa il tasto Thanks in basso a sinistra.
    Prima di postare leggi sempre la prima pagina del thread.
  5. #2034
    Ladispoli (RM)
    Galaxy S4 , S II
    Prova così......
    Freq step = 100
    Nnt.... Lagga...
  6. #2035
    Nnt.... Lagga...
    Metti anche lo smooth up a 0 e il fast scaling a 0......
  7. #2036
    Androidiano L'avatar di Aravs
    Ringraziato 56 volte in 23 Posts
    ecco quì i settaggi per come configurare al meglio il governor Zzmoove
    Settaggi
  8. #2037
    Androidiano VIP L'avatar di HyperAbarth
    Honor 10
    Ringraziato 446 volte in 348 Posts
    Con cosa è possibile modificare i settaggi di questo Kernel? (Da Recovery? Con App?)
    A me interesserebbe Undervoltare e abbassare la Frequenza Minima (es. da 200 a 100).
    Se ti sono stato d'aiuto --> un click sul Thanks qui sotto a Sinistra
  9. #2038
    Xiaomi redmi note 3 pro
    Ringraziato 38 volte in 36 Posts
    Cpu adjuster
  10. Il seguente Utente ha ringraziato bixi per il post:
    HyperAbarth (12-05-13)
  11. #2039
    Dopo qualche giorno di utilizzo posso affermare che questo nuovo zzmoove è davvero un ottimo governor......
    I risultati che ho ottenuto sono simili a quelli che riesco a fare con l'Apolo (anche se ha un undervolt più spinto).....
    Ho aggiunto il profilo che sto utilizzando nel mio Dropbox.... chi fosse interessato può trovare il link al 2º post
    Nota: il profilo va copiato nella cartella "CpuProfiles" presente nella sd esterna..... se non avete la sd esterna allora guardate in quella interna
    Ultima modifica di N1m0Y; 12-05-13 alle 23:11
  12. Il seguente Utente ha ringraziato N1m0Y per il post:
    bluflight13 (12-05-13)
  13. #2040
    Ladispoli (RM)
    Galaxy S4 , S II
    Bene ci siamo quasi... Non ai livelli del pegasusq ma può andare...
    Ora avendo 3 profili... Hai qualche Settaggio per lo screen off? Sempre se puoi e non ti è di disturbo
    (il 3 è per i giochi li ho lasciato il pegasusq)
    Ultima modifica di federico54; 12-05-13 alle 23:21
