[KERNEL] CF-Root 6.3 - SuperSU+CWM5.5+CWMManager
    Senior Droid L'avatar di KURTZ
    Feb 2011
    Regione FVG
    NEXUS
    Ringraziato 91 volte in 59 Posts
    Thumbs up
    Chainfire ha appena rilasciato la versione del kernel cf@root per questo terminale qualcuno lo ha provato?
    [18.06.2012] CF-Root 6.3 - SuperSU+CWM5.5+CWMManager - xda-developers
    Come si installa (desktop) ODIN
    Short: unpack the ZIP download, you will end up with a TAR, flash this in ODIN as PDA, and optionally install and run Triangle Away afterwards to reset the flash counter. Beware that this should boot your device into recovery mode (for a few seconds to install SuperSU and CWM Manager) after flashing. Sometimes it doesn't, just flash it again in that case.
    Metodo rapido: scompattare il file ZIP una volta e troverete un altro file TAR, inseritelo nel campo PDA di ODIN e il gioco è fatto; dopo di che potete installare Triangle Away per resettare il counter. Attenzione questo metodo potrebbe far partire il vs. terminale in recovery mode (questo serve ad installare SuperSU e CWM Manager) appena dopo il flash. Può succedere che questo non succeda, in questo caso procedete con il flash ancora una volta.
    Long:
    - Follow these instructions to the letter. Do not touch any buttons or checkboxes that are not listed below to touch!
    - Unzip the attached Odin3-vX.X.zip file
    - Download and unzip the CF-Root-SGS3-vX.X.zip file (see posts below this one)
    - If you end up with a recovery.img and cache.img file, you've extracted twice. You need to end up with a .tar file - don't extract that one
    - (USB) Disconnect your phone from your computer
    - Start Odin3-vX.X.exe
    - Click the PDA button, and select CF-Root-SGS3-vX.X.tar
    - Put your phone in download mode (turn off phone, then hold volume-down + home + power to boot - if it asks you to press a button to continue, press the listed button, or run adb reboot download command)
    - (USB) Connect the phone to your computer
    - Make sure Repartition is NOT checked
    - Click the Start button
    - Wait for Android to boot
    - Done (if it took you more than 30 seconds, you need practise!)
    Lungo:
    - Seguite questa guida alla lettera non toccate nessun bottone o casella che non sia espressamente segnalata qua sotto;
    - Scompattate Odin3-vX.X.zip
    - Scaricate e scompattate il seguente file: CF-Root-SGS3-vX.X.zip file
    - Se dopo aver scompattato il file vi ritrovate i seguenti recovery.img e cache.img files significa che avete scompattato due volte il file contenente il kernel;
    - Scollegate il vs. terminale dalla porta USB;
    - Lanciate Odin3-vX.X.exe
    - Selezionate PDA ed inserite il file: CF-Root-SGS3-vX.X.tar
    - Mettete il vs. terminale in Download Mode (classica combinazione dei tre tasti)
    - Connettete il vs. terminale alla porta USB del vs. PC
    - Assicuratevi che REPARTITION NON sia selezionata
    - Selezionate START
    - Attendete che Android riparta
    - FATTO
    Ultima modifica di KURTZ; 20-06-12 alle 10:28
    Monza
    GNote2 Htc One Black LG G4
    Feb 2011
    Regione FVG
    NEXUS
    Quote Originariamente inviato da serpent71 Visualizza il messaggio
    si ma questo è + preciso e completo
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da KURTZ Visualizza il messaggio
    esiste gia un thread guida, e viene regolarmente aggiornato,tanto è vero che già lo abbiamo flashato, disperdere le notizie e duplicare le guide non è un bene
    ma tu non lo hai nemmeno provato?
    poi più preciso e completo dell'altro?
