Enr1988
Dedicato a chi vuole maggiori prestazioni rispetto al profilo da me suggerito in prima pagina, ecco una rivisitazione testata negli ultimi 2 gg..
Qui il
https://www.dropbox.com/s/amdqu2peod...efault.profile download del profilo e seguire le istruzioni in prima pagina
internal_iosched=sio
sd_iosched=zen
internal_read_ahead_kb=1024
sd_read_ahead_kb=2048
CONFIG_BOOTED=true
CONTROLSWITCH_CPU=on
scaling_max_freq=1500000
scaling_min_freq=200000
CPU_VOLT_1800=1400000
CPU_VOLT_1704=1350000
CPU_VOLT_1600=1250000
CPU_VOLT_1500=1250000
CPU_VOLT_1400=1187500
CPU_VOLT_1300=1137500
CPU_VOLT_1200=1087500
CPU_VOLT_1100=1037500
CPU_VOLT_1000=987500
CPU_VOLT_900=950000
CPU_VOLT_800=900000
CPU_VOLT_700=875000
CPU_VOLT_600=862500
CPU_VOLT_500=837500
CPU_VOLT_400=825000
CPU_VOLT_300=800000
CPU_VOLT_200=800000
scaling_governor=pegasusq
sampling_rate=40000
sampling_down_factor=1
up_threshold=88
down_differential=5
freq_for_responsiveness=400000
up_threshold_at_min_freq=60
freq_for_fast_down=1200000
up_threshold_at_fast_down=95
freq_step=37
up_threshold_diff=6
freq_step_dec=13
flexrate_enable=on
flexrate_max_freq=800000
flexrate_forcerate=0
cpu_up_rate=12
cpu_down_rate=24
up_nr_cpus=1
hotplug_lock=0
max_cpu_lock=4
min_cpu_lock=0
hotplug_freq_1_1=800000
hotplug_freq_2_0=500000
hotplug_freq_2_1=1000000
hotplug_freq_3_0=900000
hotplug_freq_3_1=1200000
hotplug_freq_4_0=1100000
hotplug_rq_1_1=175
hotplug_rq_2_0=175
hotplug_rq_2_1=275
hotplug_rq_3_0=275
hotplug_rq_3_1=375
hotplug_rq_4_0=375
cpu_online_bias_count=2
cpu_online_bias_up_threshold=65
cpu_online_bias_down_threshold=30
CONTROLSWITCH_BUS=off
BUS_sampling_rate=100000
BUS_load_history_size=5
BUS_dmc_max_threshold=30
BUS_idle_threshold=4
BUS_max_cpu_threshold=20
BUS_up_cpu_threshold=11
BUS_cpu_slope_size=7
BUS_INT_VOLT_100=862500
BUS_INT_VOLT_133=900000
BUS_INT_VOLT_160=937500
BUS_INT_VOLT_200=1012500
BUS_MIF_VOLT_100=900000
BUS_MIF_VOLT_133=900000
BUS_MIF_VOLT_160=900000
BUS_MIF_VOLT_267=950000
BUS_MIF_VOLT_400=1050000
Dyn_fsync_active=on
dcp_ac_input_curr=1000
dcp_ac_chrg_curr=1000
sdp_input_curr=900
sdp_chrg_curr=900
cdp_input_curr=1000
cdp_chrg_curr=1000
ignore_stable_margin=off
ignore_unstable_power=off
batt_chrg_hard_volt=2
batt_chrg_soft_volt=4300000
fb_delay=0
hook_intercept=on
sequence_intercept=on
s_digital_noise_reduction_mask_14=off
s_digital_noise_reduction_mask_16=off
s_factory_digital_noise_reduction=off
s_high_dynamic_range_mask_14=off
s_high_dynamic_range_mask_16=off
s_factory_high_dynamic_range=off
s_edge_enhancement_mask_1=off
s_edge_enhancement_mask_14=off
s_edge_enhancement_mask_16=off
s_edge_enhancement_mask_64=off
s_factory_edge_enhancement=off
de_positive_e=0
de_positive_f=0
de_min_ratio=0
de_max_ratio=0
s_chroma_saturation=off
s_factory_chroma_saturation=off
cs_weight=0
cs_red=0
cs_green=0
cs_blue=0
cs_yellow=0
cs_cyan=0
cs_magenta=0
s_MCM=off
mcm_temperature=-6
s_channel_filters=off
scr_white_red=-5
scr_white_green=0
scr_white_blue=0
scr_red_red=0
scr_red_green=0
scr_red_blue=0
scr_green_red=0
scr_green_green=0
scr_green_blue=0
scr_blue_red=0
scr_blue_green=0
scr_blue_blue=0
scr_yellow_red=0
scr_yellow_green=0
scr_yellow_blue=0
scr_cyan_red=0
scr_cyan_green=0
scr_cyan_blue=0
scr_magenta_red=0
scr_magenta_green=0
scr_magenta_blue=0
