Io non sono lo sviluppatore del kernel, il dev è
AndroidGX !
"Questa è un kernel
STOCKcon caratteristiche
MINIMALI.
L'obiettivo è quello di offrire una leggera modifica del Samsung kernel stock, con l'obiettivo di una durata della batteria migliore senza alterare le prestazioni
Si tratta di un kernel "
plug-and-play", o direi più "f
lash-and-play". Non c'è bisogno di strumenti o applicazioni per configurare il kernel. Un po' come il kernel SpeedMod."
ESCLUSIVAMENTE PER ROM SAMSUNG 4.1.2
Caratteristiche:
- Based on update11 sources from Samsung.
- zzmoove (v0.7b) governor (added and set as default).
- row (v4) scheduler (added, need Trickster MOD to set it, or an init.d script).
- Wolfson Boeffla Sound (1.6.0 drivers) compatibility (saturation prevention REMOVED for much better sound).
- Touch-to-Wake v1.1 (enabled by default with 5 seconds delay).
- init.d support.
- CRT-off effect support (early_suspend set to 100ms).
- USB charging increased (to 700 instead of 475 by default).
- ExFAT, CIFS and NFS support.
- xbox controller support.
- Triangle Away support.
- Compiled with Linaro GCC 4.7.4 toolchain (for better optimization and performance).
- Ramdisk from XXEMF6 (for update10 ROMs compatibility without the need to change radio).
Various Tweak:
- Hardcore mDNIe tweaks (for better colors + sharpness fix for better readability).
- AndiP's dynamic sync control v1.1.
- ARM CPU topology.
- ROW scheduler & blk-core tweaks.
- KBUILD compiling optimizations.
- Dynamic Screen Frequency Scaling
- Network speed tweak.
- Reduced WiFi wakelock.
- Android logger disabled.
- Disabled some kernel debugging feature (Samsung/sec_log/last_kmsg).
- Disabled touchscreen debugging.
- Removed debug logging for some drivers (touchscreen/modem/max77686/sec_watchdog).
- Reduced battery-monitor wakelock timeouts.
- Proportional Rate Reduction for TCP.
- Change packet filter settings to block multicast.
- Allow manual brightness to 300 candela.
- AIO tweak: No plug I/O queue in "do_io_submit()".
- MMC : Increased timeout limits for bad sdcards.
- bcmdhd : Disabled multicast on suspend.
- cpu_load_slope correctly set.
- CONFIG_SCHED_AUTOGROUP enabled
- Wakelock : use single threaded workqueues.
Se apprezzi il lavoro dello sviluppatore ringrazialo con una donazione!
Download v3.6
