io vorrei installare l'archikernel per rom samsung kitkat ora la rom che ho io ha gia di suo il kernel boeffla 7.7 posso flashare tranquillo? oppure è considerato come kernel custom e rischio il brick?1. Make sure that you have stock kernel already flashed (the one which comes with your ROM), if you're running custom kernel already, reflash your ROM without wipe, this will also flash stock kernel. This is ultimately important, DON'T FLASH ARCHIKERNEL ON ANOTHER CUSTOM KERNEL, you may face various issues you've never seen before.
* This is because ArchiKernel uses AnyKernel method - it pulls ramdisk from your current kernel. If you brick your phone by flashing AK on top of custom kernel, you know who will be responsible for that.
EDIT: ho flashato e non faceva il boot continuava a ricaricare la schermata galaxy s3 allora ho flashato il boeffla e la rom è ripartita... perchè? il kernel stock della mia rom è il boeffla...
