efeXTREME KitKat ROM based on QS-i9300-KK
Thread XDA quì
CHANGELIST BETA 1
Based on KitKat N7100 port.
Base ROM: QS-i9300-KK.
Rooted.
BusyBox.
Support init.d.
Support /data/ directory.
SuperSU v2.01.
Lastest zipaling.
Build.prop tweaks.
Integrated Boeffla kernel 6.0 stable.
Boeffla Config app.
Xposed Framework.
Added S5 apps and full interface.
And many many more...
CHANGELIST BETA 2
Based on QS-i9300-KK v2.5 (N7100XXUFNG4 port).
Updated SU to v2.02.
Updated Busybox.
Updated Xposed Framework.
Updated to S5 Mini apps.
Updated SystemUI.
Updated Framework.
Lastest smali/baksmali.
Lastest zipaling.
Removed Boeffla kernel.
Removed Boeffla Config app.
Removed SFinder & Quick Connect.
Removed Flipboard.
Removed useless background processes.
Fixed Screen Mirroring & Wi-Fi Direct.
Fixed SmartScroll.
Fixed OTA Updater missmatch ID.
Fixed FC at changing lockscreen wallpaper from Settings.
Added QS-i9300-KK stock kernel.
Added UPSM Manager.
Some visual changes here and there.
And many more...
FEATURES
S5 User Interface.
S5 SystemUI.
S5 Settings.
S5 Task Manager.
S5 Launcher with My Magazine.
S5 Accuweather Widget.
S5 Lockscreen.
S5 Keyguard.
S5 CallUI.
S5 Contacts.
S5 Messages.
S5 Keyboard with colored emojis.
S5 Browser.
S5 My Files.
S5 Calculator.
S5 Music.
S5 Video Player.
S5 Gallery.
S5 Planner.
S5 SVoice.
S5 Email.
S5 Memo.
S5 Voice Recorder.
S5 Radio.
S5 SFinder.
S5 Quick Connect.
S5 Toolbox.
S5 Power Saving Mode.
S5 Ultra Power Saving Mode.
S5 Multiwindow.
Smart Stay.
Smart Pause.
Smart Scroll.
OTA Updates.
SCREENSHOTS
DOWNLOADS
efeXTREME KitKat-ROM beta 2
Full wipe raccomandato per una installazione pulita.
Versioni precedenti
Kernel alternativi
Boeffla Kernel Beta
PSN AGNi Stock v4.5
ArchiKernel v1.4
BUG NOTI
-Se imposti una suoneria personalizzata per un contatto tramite l'app Contatti ci sarà un FC. Puoi impostarla tramite l'app Musica o Archivio.
-Uso con una mano.
-Potrai vedere qualche glitch grafico, raramente.
-Se metti a caricare il telefono da spento, si avvierà automaticamente.
TWEAKS
-Controlla che il risparmio energetico non sia attivo quando non serve.
-Vai in impostazioni > altro > Opzioni sviluppatore e cerca "Animazione di ridimensionamento finestra", "Ridimensionamento animazione finestra" e "Ridimensionamento durata Animator". Imposta queste tre opzioni a 0.5x.
-Vai in impostazioni > altro > Opzioni sviluppatore > limite processi in background e impostalo ad almeno 2 processi.
-Se stai usando il Boeffla kernel con un profilo di risparmio energetico ci sarà qualche lag a volte.
-Quando la RAM è troppo piena, svuotala dall'apposito menù.
-Se stai usando il Boeffla kernel apri l'app Boeffla Config e vai su Miscellaneous tab > Sovrascrittura Swappiness, attivatela e impostatela a 60 o 80.
-Usa Greenify.
