anche io , nonostante sia stato ben attento a non mettermi knox, mi sono messo a leggere un po.. OT su google translate hai ragione
ATTENZIONE!!! non voglio con questo dare il via libera al modding sfrenato e chissene del knox... NO!! non voglio telefoni con mancata garanzia sulla coscenza!!
questa potrà anche essere la teoria, ma come è stato riportato diverse volte la pratica va ben diversamente!! quindi occhio sempre a quello che fate perchè l' assistenza non lo ripara e non so se conviene andare per vie legali !!!
tread xda da cui sono partito per la ricerca
[INFO][EU] Rooting and Flashing don't void the warranty - xda-developers
poi ho scovato questo post sul FSFE ( Free Software Foundation Europe)
Does rooting your device (e.g. an Android phone) and replacing its operating system with something else void your statutory warranty, if you are a consumer?
che mi ha portato alla direttiva 1999/44/CE
EUR-Lex - 31999L0044 - EN
in breve come riportato al secondo link che qui quoto
che tradotto diventa:If your device becomes defective in the first 6 months, it is presumed that the defect was there all along, so you should not need to prove anything.
If your device becomes defective after the first 6 months, but before 2 years run out, you are still covered. The difference is only that if the defect arises now, the seller can claim that the defect was caused by some action that was triggered by non-normal use of the device(4). But in order to avoid needing to repair or replace your device, the seller has to prove that your action caused(5) the defect. It is generally recognised by courts that unless there is a sign of abuse of the device, the defect is there because the device was faulty from the beginning. That is just common sense, after all.
(4) E.g. a defect power button could be caused by spreading marmalade in it or hooking it onto a robot that would continuously press the button every second 24/7 — of course that is not normal or intended use.
(5) Note that correlation is not causation — the defect has to be proven to be caused by your action, not just correlate with it.
a voi le conclusionise il votro dispositivo diventa difettoso entro i primi 6 mesi, si oresume che il difetto fosse presente dalla produzione, e non si deve provare nulla.
se il vostro dispositivo presenta dei difetti dopo i primi 6 mesi dall' acquisto, ma prima dei 2 anni, siete sempre coperti. la differenza è solo che se il difetto si presenta ora, il venditore/produttore puo lamentare che il difetto sia stato causato da qualche azione dovuta ad uso non normale del dispositivo (4). ma per evitare di dover riparare o sostituire il prodotto, il venditore deve dimostrare che la vostra azione ha comportato il danno (5). è generalmente riconosciuto dai giudici che a meno di segni di abuso, di danno è causato da un difetto di produzione del prodotto. come è buonsenso.
(4) es un tasto power difettoso puo essere dovuto al fatto che ci avete spalmato la marmellata sopra, o consegnandolo ad un robot che spinge il tasto ogni secondo 24h su 24 7 gg su 7, che ovviamente non è uso normale o utilizzo previsto
(5) notare che correlazione non è causa - deve essere provato che è causato da voi non solo correlato.
