Utente del giorno: fracarro con ben 10 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: fracarro con ben 38 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 186 Thanks ricevuti nell'ultimo mese
Pagina 11 di 19 primaprima ... 910111213 ... ultimoultimo
Visualizzazione dei risultati da 101 a 110 su 187
*[ROM GT I9505 [4.4.4] [JFLTE] Mahdi-Rom 2.9 Final
  1. #101
    Ringraziato 14,089 volte in 9,323 Posts
    Nuova build
    Quote Originariamente inviato da Mahdi786 Visualizza il messaggio
    New build is up
    http://www.androidfilehost.com/?fid=23501681358555528
    -Theme chooser: upstream fixes/updates from CM
    -Added HeadsUp with blacklist, do not disturb and qs tile
    -Hover updates from AOSPA, also added an option to hide from lock screen
    -Slim recents: option to show topmost task and other fixes from Slim
    -Lots of other framework fixes (read the detailed changelog)
    -Updated boot animation thanks to @blazze11
    -Settings: fixed battery stats app list
    -Settings: Use a seekbar preference to allow setting arbitrary animation scale values
    -Launch SuperSU from Settings and hide SuperUser if SupenSU is installed
    -Trebuchet: fixed GEL integration
    -Mms: Use the nice colorful LetterTileDefaultImages
    -Incallui: make navigation bar translucent
    -All CM apps merged
    -Added option to turn torch off when screen turns off
    -Camera: added Transparent Popups menus thanks to @rush25
    -Tanslation updates thanks to @c@p, @seilogeo, @toyr99 and @Pixelase
    Jflte
    -Kernel updated to Linux 3.4.95
    -Add hardware tunables (AdaptiveBacklight support, high touch sensitivity)
    *Note high touch sensitivity isn't working because I missed one commit in hardware so the option in display settings wont have any effect
    **If you find a bug please capture a bug report and pm it to me
  2. Il seguente Utente ha ringraziato Anna per il post:
    SupremeFlash (01-07-14)
    Jun 2014
    Samsung Galaxy S4
    Quote Originariamente inviato da JacOcaJ Visualizza il messaggio
    Nuova build
    Grazie! Un kernel alternativo allo stock molto performante c'è?
  5. #103
    Quote Originariamente inviato da SupremeFlash Visualizza il messaggio
    Qualche volta ho provato il kt
    Io comunque preferisco il suo
  6. #104
    Senior Droid L'avatar di Simoxine
    LG Nexus 5
    Ringraziato 89 volte in 79 Posts
    Che modem usate su questa rom? L'ho appena installata e ho problemi con lo switch 2g/3g, praticamente nel menu della selezione delle reti ci sono un'infinità di voci e se provo a cambiare crasha il processo android.phone, operatore 3 e modem kitkat nc5, mahdi 2.7
  7. #105
    Quote Originariamente inviato da Simoxine Visualizza il messaggio
    Credo che vadano bene tutti... Comunque io ho usato nf1 ultimamente
    Il problema che dici però è un bug della versione non c'entra il modem
  8. Il seguente Utente ha ringraziato Anna per il post:
    Simoxine (05-07-14)
  9. #106
    LG Nexus 5
    Nella 2.6 funziona tutto correttamente?e in tal caso da dove posso scaricarla?
    Ultima modifica di Simoxine; 05-07-14 alle 10:08
  10. #107
    Si, ma anche nella versione 2.7 del 21 giugno... Però dovresti trovarla
  11. Il seguente Utente ha ringraziato Anna per il post:
    Simoxine (05-07-14)
  12. #108
    Nuova versione
    Build is up guys, I'll update the op with link soon
    Rom
    http://www.androidfilehost.com/?fid=23501681358561973
    Experimental kernel
    http://www.androidfilehost.com/?fid=23501681358562014
    Ultima modifica di Anna; 14-07-14 alle 07:16
  13. #109
    Ringraziato 27 volte in 20 Posts
    Ciao Ragazzi.. ho messo sull'S4 della mia ragazza l'ultima versione della Mahdi e mi ha chiesto come si può fare una videochiamata classica, non si possono fare?
    Inoltre volevo chiedervi se è normale che durante l'avvio del telefono appaiono in alto a sinistra delle scritte minuscole di cui la prima rossa.
    E per finire quali sono le ultime versioni di bootloader e modem per il nostro S4 e dove posso trovarli.
    Edit: dimenticavo di chiedervi se per questo telefono di può attivare in qualche modo l'accensione delle schermo con doppio tocco, devo cambiare kernel? E usare un app apposita? Se si quale app e kernel?
    Grazie mille
    Ultima modifica di Dalcielo; 19-07-14 alle 13:09
  14. #110
    Nuova build in arrivo
    New build is up, servers will be updated later today.
    http://www.androidfilehost.com/?fid=23578570567715384
    -Updated to 4.4.4_r2
    -HeadsUp fixes from Slim and CM
    -Privacy Guard notification options
    -Added an option to disable hardware navigation buttons
    -Settings restructure: distributed features to appropriate places, no more cutomization screen
    -Settings: fix force close in security settings when lock screen security is set to none
    -Settings: Fine LongPress and hold delay
    -Added gesture settings for 1+1
    -Trebuchet: merged with CM and added CMHome app for use with Trebuchet (it displays extensions and supports Dash Clock)
    -Various fixes in Browser, Mms, Dialer and ThemeChooser
    -There have been lot more fixes so take some time to read the detailed changelog
