Mahdi786
New build is up,
https://www.androidfilehost.com/?fid=23622183712466402
-Theme chooser: upstream fixes
-AppOps: fix checking user permissions before enabling/disabling wifi
-Add persistent notification when USB OTG is connected
-Fix slim recent panel defaulting to white on clean flash
-Add reverse lookup provider "Das Telefonbuch" (DE)
-Setup wizard cleaned up, much cleaner experience
-Fixed a bug in quiethours qs tile which caused high battery drain
-APN updates
*Frameworks and settings clean up
-spent some time looking through these projects and cleaned up things
in services, keyguard, systemui and settings
*Lockscreen notifications improvements and fixes
add option to:
-enable/disable if notification is actually dismissed
-force enable low priority notifications
-fixed nullpointers
*Blacklist
fixed:
-not being able to add short numbers
-force close when blacklist button was pressed in in-call ui
*Enabled some options by default on a clean flash and fixed some options which shouldnt have been enabled
default:
-circle battery
-double tap status bar to sleep
-notification count
-quicksettings quick pulldown to the right
diabled:
-screen on led
-flip tiles and vibrate tiles
-recents clear all
-navbar ime cursor
*Removed options:
-custom lockscreen color options
-quiethours auto sms, call bypass
-battery saver led and vibrate option
-Tanslation updates thanks to CM, @
seilogeo, @
toyr99, @
Pixelase, @
The Tox, @
michaelz93,
@Alberto97 and @
jbnitro
-Big Japanese translation update (not sure if your a user on xda but good work)
Enjoy.
