Pagina 3 di 10 primaprima 12345 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 98
[ROM i9505][jflte][4.4.x] SlimSaberKat [Unofficial SlimKat] Stabile e Battery friend
  1. #21
    Androidiano VIP L'avatar di S4rr4cino
    Htc; Sam. S, S2, S4, Nt3, Op3t
    Ringraziato 307 volte in 266 Posts
    Dopo ben 20 giorni ho deciso di aggiornare la rom del mio amato S4, mi è sembrata quasi un'operazione inutile, quando il giocattolo funziona strabene perché rischiare? Però tante volte non si sa mai, metti che il dev mi stupisce
    Ecco gli ultimi cambiamenti:
    Quote Originariamente inviato da kantjer Visualizza il messaggio
    Changelog:
    Official SlimKat Changelog[/SIZE]
    Additional changes in SlimSaberKat compared with the official SlimKat:
    • Built for speed using SaberMod 4.8.4 toolchain and build optimizations
    • Alucard kernel included (built with SaberMod 4.9.2)
    • Backup and restore script for Xposed binaries when doing an upgrade
    • Modified gps.conf, for faster GPS fix
    • Included optimized kernel profiles
    • Reverted "UNOFFICIAL Builds are for Developers and Testers!" commit to remove debug info and keep inline with official version
    • Added SlimSaberKat version to the "About phone"screen
    • Option to answer call with hardware HOME button
    • Changed default screen DPI to 420 (will only affect clean installs)
    • Fixed ad-blocker script in STweaks, thanks to @hawkerpaul
    • Fixed database optimization script in STweaks
    • New bootanimation thanks to @DJDobermann
    • removed 5 second delay to open apps after pressing home button
    • SlimOTA working for SlimSaberKat, will work for every new release
    Changelog last version:
    • added Quiet Hours System Sounds
    • added Slimrecents background color && transparency
    • kernel updated (I highly recommend deleting data/.alucard before upgrading)
    • kernel profiles updated
    • synced with SlimKat 6.9 source
    Senior Droid L'avatar di Farmah
    Ringraziato 28 volte in 22 Posts
    Raga come aosp consigliate questa rom? La fotocamera come si comporta? Grazie
  4. #23
    Quote Originariamente inviato da Farmah Visualizza il messaggio
    Io la uso da sempre, ora su S4 e ancora prima su S2. Va perfettamente, anche la fotocamera per me fa ottime foto, certo non come la stock ma imho il compromesso è sostenibile. Se cerchi una ROM minimale questa è la ROM che fa per te. Provala e vedi come ti trovi magari con un nandroidbackup torni indietro in un niente se non ti garba
  5. Il seguente Utente ha ringraziato S4rr4cino per il post:
    Farmah (03-08-14)
  6. #24
    Androidiano VIP L'avatar di molochgrifone
    Ringraziato 390 volte in 331 Posts
    Una domanda: che differenza c'è tra questa e la slimkat?
    Ovvero le modifiche fatte dal dev quanta influenza hanno?
    Ultima modifica di molochgrifone; 04-08-14 alle 07:06
    Il tasto thanks non ha mai ucciso nessuno
  7. #25
    Quote Originariamente inviato da molochgrifone Visualizza il messaggio
    È il tools che ha usato per riscrivere la ROM che la rende diversa.
    Da quanto ho capito la ROM sfrutta dei drive alternativi del tool (SaberMod) per garantire non solo un'ottima fluidità generale ma anche un'ottima durata della batteria. Poi ci sono sempre le sue personalizzazioni come il kernel Alucard, che rispetto al kernel originale è molto più parsimonioso.
  8. #26
    In ferie la proverò, ora mi serve troppo il telefono per lavoro e io sono un maniaco della configurazione manuale! A presto per i feedback
  9. #27
    Anch'io sono come te e il telefono è la mia memoria in tutti i sensi, lo uso per qualsiasi cosa ormai, e la mia ROM preferita deve essere minimale, fluida e parsimoniosa proprio come la SlimSaber perché sono molto amante delle personalizzazioni e quindi è meglio avere il minimo indispensabile alla base. A presto.
  10. #28
    Androidiano VIP L'avatar di kessa92
    Moto X (2014), Tab Onda V975m
    Ringraziato 91 volte in 85 Posts
    interessato ad un cambio rom, ho vari problemi con la imperium ai quali non mi rispondono , ho visto questa rom, la proverò. non so qual'è la differenza tra le gapps da flashare. proverò questa, la mini: Slim_mini_gapps.4.4.4.build.7.x-187
    è quella con più download, spero bene
    Ti ringrazio per ora.
    EDIT:
    Come faccio il root? Come se avessi la ROM originale Samsung?
    Ultima modifica di kessa92; 06-08-14 alle 06:19
    Per Onda V975m:
    MEGA
    Flashabili tramite recovery modificata, tranne il file icone s5 che è utilizzabile tramite nova (fare un backup delle proprie opzioni nova prima di importare questo)
  11. #29
    Quote Originariamente inviato da kessa92 Visualizza il messaggio
    EDIT:
    Se hai la imperium hai GIÀ il root
    A proposito di gapps, io fossi in te flasherei le mini, ma si può sapere cosa è compreso nelle varie versioni mini/standard/full?
    Ultima modifica di molochgrifone; 06-08-14 alle 06:31
  12. Il seguente Utente ha ringraziato molochgrifone per il post:
    kessa92 (06-08-14)
  13. #30
    EDIT:
    A voi va ART? A me non la seleziona. O meglio la imposto ma al riavvio è ancora dalvik.....
    Ultima modifica di kessa92; 06-08-14 alle 14:04
    Per Onda V975m:
    MEGA
