bluflight13
* Nuova versione V1.4h For 4.4 AOSP V2 (NEW CM) disponibile in prima pagina:
[quote name="alucard_24" post=55834188]Hello guys,
I worked alot on new kernel AOSPV2, so it is time to release it
Download link is at first post.
Changelog:
v5 - 04/10/2014 (Kernel-Alucard-V1.4h)
*Merged CPUFREQ fixes that improve performance.
*Merged updates for CPUFREQ and SCHED CORE code.
*Merged HUGE update to Power Manager and QOS Code.
*Replaced old Early Suspend with Power suspend. I am the first one to import this feature for S4. Thanks to @
neobuddy89 and @
dorimanx for their code.
*Removed DYNAMIC FSYNC. It could cause kernel panic if used with ASYNC FSYNC.
I/O. Performance are reduced but stability is improved
*Merged HUGE update to CPUIDLE code.
*Merged HUGE update to Kernel IRQ distribution Domain.
*Merged HUGE update to FileSystem code and Kernel System code.
*Merged NET code update.
*Tuned MSM and Intelli HotPlugs.
*Fixed stuck SuperSU service on boot.
*Added new control to STweaks, that allow to use faster kernel workqueue or more power saver.
*Updated with 3.4.104 main line patches.
*Updated MSM RQ STATS code to better support Default HotPlug
*Merged HUGE update to CPUIDLE code that responsible for CPU sleep and power up on need from IDLE to full power and fast back to idle. Code is very complicated and many bugs are fixed with this huge port from 3.10.y tree.
*Merged HUGE update to Power Mode Domains, this code responsible for powering down drivers on deepsleep and waking them on wakeup.
Many bugs are fixed and many new things added that make this code a lot faster and safe.
*Merged updates to persistent RAM driver.
*Merged code updates to SCHED CORE.
*Merged performance boost code for Cortex A15 CPU that we have!
*Merged serious update from TEGRA 3.10.y kernel for CPUIDLE relaxation. This code will help to save power when CPU is not loaded, so kernel will idle much better and not looping useless CPU cycles. when there is nothing to do.
*Merged SMP and Unalligned patches to speed up the code process.
*Merged CGROUP protection patch.
*Merged updates to Qseecom driver.
*Merged updates to MMC driver. We have new MMC code now.
*Merged latest Seccomp driver.
*Merged updates to android binder.
* Performace improved a lot!
Thanks to @
dorimanx for part of his changelog.
