Utente del giorno: Varioflex con ben 2 Thanks ricevuti nelle ultime 24 ore
[ROM][TW][OF2][5.0.1] Osiris ROM v1.0
    Androidiano VIP L'avatar di peppe130
    Samsung Galaxy S6 SM-G920F
    Ringraziato 1,434 volte in 1,032 Posts
    Osiris ROM v1.0
    Features
    • Based on stock Lollipop Firmware I9505XXUHOF2
    • Deodexed, Zipaligned, Debloated
    • 100% Knox Free
    • Imperium Kernel v2.1
    • Rooted (SuperSU v2.46)
    • Added Busybox
    Mods
    • Removed Signature Check
    • Added 5Way Reboot Menu
    • Disabled Software Update Menu
    • Enabled native VoiceCall recording
    • Enabled Camera during Call
    • Enabled Scheduled Messages
    • Enabled Call/Message Block Menu in Settings
    • Added 3Minit Battery Mod
    • Enabled NFC Icon
    • Added S4 AccuWeather
    • Added S5 AccuWeather
    • Added S6 AccuWeather
    • Added Note 4 AccuWeather
    • Added S4 Bootanimation
    • Added S6 Bootanimation
    • Added S4 My Files
    • Added S5 My Files
    • Enabled Theme Chooser (S4 TouchWiz)
    • Added 16 TouchWiz Themes for Theme Chooser
    How to install
    Download and flash this Philz via Odin.
    • Download the ROM and check the MD5 hash using winMd5Sum.
    • If the MD5 hash matches with the one in this thread, you can copy the ROM on the Internal/External storage.
    • Reboot into recovery mode.
    • Make a nandroid (Backup and Restore > Backup to /sdcard or Backup to /storage/sdcard1)
    • Press on Install Zip, choose the storage and press on the ROM's Zip file.
    • Follow the Aroma Installer Wizard.
    • Reboot your device. First boot may take 10-15 minutes.
    Download
    MD5: f942f9577c2590277d0709ff14b83e45
    XDA DevDB Information
    Osiris ROM For Samsung Galaxy S4 I9505, ROM for the Samsung Galaxy S4
    Contributors
    @peppe130
    @wuby
    @daxgirl
    @Slim80
    @bluflight13
    @Albe95
    @CJCris97
    ROM OS Version: 5.0.1 Lollipop
    Version Information
    Status: Stable
    Current Stable Version: v1.0
    Stable Release Date: 30-06-2015
    Created 30-06-2015
    Last Updated 30-06-2015
  2. I seguenti 2 Utenti hanno ringraziato peppe130 per il post:
    giangc (02-07-15),Peyo72 (01-07-15)
    Changelog
    Screenshot
    Riservato..
  6. #4
    Riservato..
  7. #5
    Baby Droid L'avatar di giangc
    Jun 2015
    Grande peppe👍 ROM fluida e semplice.
  8. Il seguente Utente ha ringraziato giangc per il post:
    peppe130 (02-07-15)
  9. #6
    Senior Droid L'avatar di lukas78
    Mar 2011
    Samsung Galaxy S3, S4, S5
    Ringraziato 19 volte in 13 Posts
    questa rom, una volta flashata, permette di lasciare il counter knox 0x0`?
  10. #7
    Super Droid L'avatar di Madden91
    Huawei P30 Pro
    Ringraziato 288 volte in 257 Posts
    Quote Originariamente inviato da lukas78 Visualizza il messaggio
    No, serve una recovery custom, per cui già solo flashando quella il counter scatta
  11. #8
    Mar 2011
    ma al thread ufficiale di xda, mi hanno risposto diversamente (post #275)
    http://forum.xda-developers.com/gala...9#post62496739
  12. #9
    Huawei P30 Pro
    Non è possibile, basta la custom recovery per flaggare knox, e senza custom recovery non si può flashare la rom. A meno che il buon peppe non abbia trovato il modo di fare il flash senza il flag di Knox, è impossibile evitarlo...
