Pagina 2 di 11 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 110
[Samsung Galaxy S6 Flat]Problemi e consigli Odin
  1. #11
    Nov 2009
    Quote Originariamente inviato da Misterx86 Visualizza il messaggio
    Ho chiesto perché volevo capire come stavi cercando di flashare la rom...... Come consigliato prova a pulire tutto e riprovare
    Come posso ripulire tutto? L'ideale sarebbe resettare tutto in maniera energica
    S22 Ultra,Find X2 pro,Mi 10
    Ringraziato 13,119 volte in 10,481 Posts
    Quote Originariamente inviato da Lasko Visualizza il messaggio
    Ciao a tutti
    credo di aver fatto un casino. Seguendo la guida su xda per installare una ROM modificata via ODIN, ho upgradato il BL e il MODEM in 5.1.1.
    Dopo averla seguita mi compare la scritta in rosso in alto a sinistra INVALID MAGIC STRING
    Di seguito la guida
    Do exactly step-by-step the following things:
    - Unplug your Phone (IMPORTANT!)
    - Turn your Phone completely off (This is IMPORTANT)
    - Start your Phone in download mode on this way: Press Vol down + Home + Power buttons till the screen turns on, press Vol Up to continue (Only enter download mode on this way, otherwise it won't work!!)[/B]
    - Open Odin 3.10.6 on your PC (Make sure you're using this version of Odin, other versions won't work correctly maybe!)
    - Click on the 'BL' button, and load in your BOOTLOADER tar.md5 file for your model
    - Click on the 'CP' button, and load in your MODEM tar.md5 file for your model
    - DON'T TOUCH ANYTHING ELSE (you can brick your phone if you choose other settings in Odin)
    - Now Connect your phone to your computer (DO NOT connect your phone before this step, otherwise it won't work!)
    - Click on the Start button
    - Wait till it finish flashing.
    - Your phone reboots automatically after flashing.
    - Always check after flashing: Settings -> About device -> Baseband; that should show the same modem build number noted as here.
    And also check if the bootloader got flashed correctly by downloading an AndroidTerminal app, and enter this command: getprop ro.boot.bootloader
    Purtroppo dopo questa procedura non posso più tornare indietro nè mi fa installare firmware stock (scaricati da sammobile) con ODIN. Va sempre in fail
    <ID:0/003> File analysis..
    <ID:0/003> SetupConnection..
    <ID:0/003> Initialzation..
    <ID:0/003> Get PIT for mapping..
    <ID:0/003> Firmware update start..
    <ID:0/003> SingleDownload.
    <ID:0/003> sboot.bin
    <ID:0/003> NAND Write Start!!
    <ID:0/003> cm.bin
    <ID:0/003> boot.img
    <ID:0/003> recovery.img
    <ID:0/003> system.img
    <ID:0/003> FAIL!
    <ID:0/003>
    <ID:0/003> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    Qualcuno può aiutarmi a sbloccare il telefono? Qualsiasi firmware va bene basta che si riprende!
    Rob
    Scusa ma hai i permessi di root e recovery?
    Prova a cambiare porta usb
    No
    però non è la prima volta che utilizzo questa procedura. Sull'S5 ho installato diversi firmware senza problemi.
    Cmq anche cambiando la porta USB mi fallisce sempre.
    Che posso fare?
    Quote Originariamente inviato da Wolf230 Visualizza il messaggio
    Prova a disinstallare Tutti i driver samsung (potrebbero essere rimasti alla "vecchia versione firmware), riavvia il pc, e collega il cell in download mode e lascialo ricercare da solo i driver.
    Discussioni Unite.
    Sto Guidando (cit. Dieguccio)
  4. #13
    Buongiorno a tutti,
    stavo provando a flashare sul mio s6 (con firmware h3g) il firmware originale ita con odin ma appena faccio partire la procedura il telefono si blocca; potrebbe essere per caso che io non abbia attivato il debug usb? se fosse così il telefono è da buttare? il telefono è tutto originale non ha recovery modificate o root è la prima volta che veniva flashato.
    Se provo invece a flashare il firmware originale h3g risolvo qualcosa?
    Grazie a tutti
  5. #14
    Sep 2009
    Quote Originariamente inviato da diego93 Visualizza il messaggio
    Buongiorno a tutti,
    Grazie a tutti
    Devi ovviamente mettere la medesima versione fw originale tua o superiore (esempio se hai OH2 devi mettere OH2 o superiore) per risolvere flasha il tuo originale fw h3g
  6. #15
    Ho provato diverse volte ma si blocca sempre il problema può essere legato secondo voi a windows 10? proverò anche con porte usb diverse...la situazione comunque mi sembra di aver capito è salvabile...
  7. #16
    Sep 2009
    No con w10 non ci sono problemi. Hai i driver samsung anche corretamente installati? Usa questo odin https://dl.dropboxusercontent.com/u/...n3_v3.10.7.zip, poi prova col cavo originale e cambia porta usb, riavviando anche il pc
  8. #17
    Nulla il telefono non si sblocca viene fuori una schermata di errore nell'aggiornamento software e il telefono non si riavvia se lo riporto in download mode è impossibile flashare la rom qualche altra soluzione?
  9. #18
    Sep 2009
    Ma che fw originale avevi? La sigla. E quale stai cercando di mettere, hai scaricato il tuo h3g?
  10. #19
    Questo era l'originale G920FXXU2COH2 (CSC: G920FHUI2COH1) ho provato a scaricare l'ultimo più aggiornato no-brand italia dall'apposta sezione del sito ma non riuscendo ad installarlo ho riscaricato nuovamente questo firmware ma non lo installa con nessun cavo usb e su nessuna porta usb del pc...
  11. #20
    Sep 2009
    Fai un tentativo con smart switch e vedi se ti fa il ripristino da li
