Utente del giorno: tugaia56 con ben 19 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluflight13 con ben 287 Thanks ricevuti negli ultimi sette giorni
Utente del mese: diavolo78 con ben 1154 Thanks ricevuti nell'ultimo mese
Pagina 9 di 9 primaprima ... 789
Visualizzazione dei risultati da 81 a 85 su 85
elenco GINGERBREAD e MODDING STOCK ROM
  1. #81
    Androidiano VIP L'avatar di Cecco1970
    Nov 2010
    Villafranca di Verona
    Xperia X10 ed S
    Thanks
    218
    ....dalle istruzioni pare di sì..occorre fare attenzione alle procedure differenti (lasciare lo stock kernel)
    Instructions and Advices
    This is the complete instruction for installation and configuration of ***FeraLab*** v14.2 ~Volt~ Android 2.3.9 ROM. Please read carefully.
    I tried to do my best..Hope you like it.
    Before installation please make a backup of your contacts/apps. And please remember - I'm not responsible if you make damage to your phone. It's all at your own risk!
    Warning! It is recommended that you make a Full-Wipe installation to avoid possible bugs.
    Requipments:
    - Any Rooted Rom With any Recovery
    - Baseband 71
    - Charged phone till 100%
    - Any Stock/Stock-Based Kernel
    - Patience
    Rom will work on any stock or stock-based kernel. You may stay on stock sony ericsson kernel if you want..(You need to flash wifi modules then..) Rom will be working well on it..only some tweaks may not work.
    But Highly recommended to use DoomKernel
    Installation:
    - Connect your Phone to charger and charge till 100%
    - Download and Copy my rom to your SDcard:
    * FeraLab v14.2
    - If you are on unlocked bootloader, then flash the Kernel.
    * DooMKernel_v6(Recommended. No wifi modules needed. They are already included. You need them only if you are on another kernel)
    - Now boot into any Recovery(Don't unplug charger) and:
    Format SYSTEM
    Format CACHE
    Fix Permissions
    - Then simply install rom(Install Zip). Follow the installation wizard.
    WARNING! Don't install kernel from installation package if you're on unlocked bootloader.
    - Patiently wait till Rom installs. Don't rush. It will take about 3 minutes to install. Then reboot.
    - Wait 2-5minutes. Reboot your phone and open any Recovery - Fix Permissions again.
    - Now it will be fast and stable. You can customize it as you want now. Once you finish your customization, reboot again. Also dont' unplug charger - wait till it charges till 100% again.
    Having Problems With installation?? Click HERE
    Thanks
    ho selezionato kernel stock ma ho brickato,sinceramente non capisco,ho provatoaltre rom e funzionano
  4. #83
    Thanks
    Ho avuto lo stesso problema, ho scritto anche un post. ricopio la soluzione perche non riesco a copiare i collegamenti:
    Stuck at 'Sony Ericsson' logo
    Actually I made everything to prevent this in installation scripts.. however If you made somewhere mistake or installed rom from first release then follow this steps.
    - Restore your phone to original firmware with SEUS tool (Make this only if you are on locked bootloader )
    - If you're on unlocked BootLoader , Flash DoomKernel v6
    - Root your phone and install xRecovery to your phone through latest Flashtool (search xda here)(Make this only if you are on locked bootloader)
    - Then Check if you downloaded Latest Release of my rom through my link or through mirror (also in my op.)(Don't download somewhere else)
    - Copy Rom to SD and boot xrecovery. (You can mount SD in xRecovery)
    - Go to Partition Menu and
    - Format SYSTEM
    - Format DATA
    - Format CACHE
    - Mount SYSTEM
    - Mount DATA
    - Mount CACHE
    *after you mount it should show you "Unmount -----"
    - Go to Advanced Settings and Fix Permissions
    - Then go and install my rom, following the wizard.
    - After this Reboot. Done. It should boot.
    io parto da stock 2.3.3 (ripristino con pc companion) root, xrecovery (tramite flashtool). Bootloader bloccato. Seguo le istruzioni. dopo aver seguito questi passi è partito al primo colpo
    ps è uscito feralab 15.
  5. Il seguente Utente ha ringraziato eux82 per il post:
    Cecco1970 (29-04-12)
  6. #84
    Thanks
    11
    Quote Originariamente inviato da digithom Visualizza il messaggio
    Confermo che con la Feralab V7.2 il telefono rinasce ma se volete davvero vederlo reagire come un'iphone è obbligatorio il "Launcher Pro", semplice, non lo aggiornano da una vita, ma impareggiabile come fluidità e risposta.
    Visto che il povero X10i non ha nemmeno tanta ram direi che è un must anche link2sd.
    Anche se app2sd in teoria fa la stessa cosa, link2sd sposa su sd anche la cache dell'applicazione liberando ram preziosa, inoltre, poichè le applicazioni spostate sulla SD vengono messe su una seconda partizione, che non viene smontata quando si collega il cavo usb, le app spostate su sd funzionano anche quando il cavo usb è collegato per uso memoria di massa.
    Direi che se non basta tutto questo, non resta che cambiare telefono, peccato, perchè alla fine gli manca solo un po' di ram ...
    Mi butto anch io e vorrei provare questo feralab v7, puoi indicarmi una guida sicura tipo un clone di ciò che hai fatto tu?
    Grazie mille
  7. #85
    Nov 2010
    Xperia X10 ed S
    Thanks
    218
    Quote Originariamente inviato da arsenicum Visualizza il messaggio
    Grazie mille
    E' già oro che abbia trovato una guida alternativa...ad ogni aggiornamento può cambiare uno o più passaggi, quindi conviene seguire il thread ufficiale su XDA ed eventualmente gli ultimi commenti inerenti l'ultima installazione. Oltre a questo c'è la condizione di partenza che può influire su diversi passaggi.
    In qualunque caso è opportuno avere già esperienza con recovery e flashtool e anche con altri tipici passaggi da installazione di custom ROM , quindi, è utile imparare ed informarsi prima su questi singoli strumenti.
    Ovviamente quest'ultime cose riguarda perlopiù i neofiti (quindi, se non lo sei, non ti interessa ciò che sto scrivendo ) e aggiungo di leggere i primi post di questa discussione per ulteriori avvisi/suggerimenti/informazioni utili ai neofiti, per l'appunto.
  • Non puoi inserire repliche
