Non riesco a flashare i kernel, continua a ripetermi che non c'è il driver per il dispositivo, ma prima lo avevo installato anche manualmente da flashtool stesso. Ho anche provato a cambiare da modalista MTP a MSC ma niente Ho Windows 7 64bit.
Ecco il log del flashtool64
Il telefono viene rilevato, facendo il chek dei driver li trova pure....ma dopo se li perdecodice:02/059/2013 18:59:49 - INFO - <- This level is successfully initialized 02/059/2013 18:59:49 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47 02/059/2013 18:59:49 - INFO - You can drag and drop ftf files here to start flashing them 02/059/2013 18:59:54 - INFO - Device disconnected 02/000/2013 19:00:55 - INFO - Device connected with USB debugging off 02/000/2013 19:00:55 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/001/2013 19:01:02 - INFO - Device connected with USB debugging on 02/001/2013 19:01:03 - INFO - Connected device : MT27 02/001/2013 19:01:03 - INFO - Installed version of busybox : N/A 02/001/2013 19:01:03 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54 02/001/2013 19:01:20 - INFO - List of connected devices (Device Id) : 02/001/2013 19:01:20 - INFO - - USB\VID_0FCE&PID_5173&MI_00\7&11103791&0&0000 Driver installed : true 02/001/2013 19:01:20 - INFO - - USB\VID_0FCE&PID_5173&MI_01\7&11103791&0&0001 Driver installed : true 02/001/2013 19:01:20 - INFO - - USB\VID_0FCE&PID_5173\BX903D09XY Driver installed : true 02/001/2013 19:01:20 - INFO - List of ADB devices : 02/001/2013 19:01:20 - INFO - - BX903D09XY 02/001/2013 19:01:20 - INFO - List of fastboot devices : 02/001/2013 19:01:20 - INFO - - none 02/001/2013 19:01:53 - INFO - Selected MT27i_6.1.1.B.1.10_KERNEL.ftf 02/001/2013 19:01:53 - INFO - Preparing files for flashing 02/001/2013 19:01:53 - INFO - Please connect your device into flashmode. 02/001/2013 19:01:56 - INFO - Device disconnected 02/002/2013 19:02:19 - INFO - Opening device for R/W 02/002/2013 19:02:19 - INFO - Start Flashing 02/002/2013 19:02:19 - INFO - Processing loader 02/002/2013 19:02:19 - INFO - Checking header 02/002/2013 19:02:19 - INFO - Ending flash session 02/002/2013 19:02:19 - ERROR - 02/002/2013 19:02:19 - ERROR - Error flashing. Aborted 02/002/2013 19:02:20 - ERROR - Drivers need to be installed for connected device. 02/002/2013 19:02:20 - ERROR - You can find them in the drivers folder of Flashtool. 02/002/2013 19:02:27 - INFO - Device disconnected
