Visualizzazione dei risultati da 11 a 20 su 29
Aroma Installer non installa correttamente...
  1. #11
    Caserta
    P20 / P10
    Scarica un altro firmware ... probabilmente quello che avevi non é buono. La procedura con flashtool si conclude normalmente e senza errori?
    Androidiano L'avatar di S0nyXo
    Fermignano (PU)
    Sony Xperia Sole
    Ringraziato 12 volte in 5 Posts
    10/018/2013 10:18:47 - INFO - <- This level is successfully initialized
    10/018/2013 10:18:47 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00
    10/018/2013 10:18:52 - INFO - Device disconnected
    10/045/2013 10:45:28 - INFO - Device connected in flash mode
    10/045/2013 10:45:30 - INFO - Selected MT27i / 6.1.1.B.1.10 / Global
    10/045/2013 10:45:30 - INFO - Preparing files for flashing
    10/045/2013 10:45:30 - INFO - Please connect your device into flashmode.
    10/045/2013 10:45:31 - INFO - Opening device for R/W
    10/045/2013 10:45:31 - INFO - Reading device information
    10/045/2013 10:45:32 - INFO - Phone ready for flashmode operations.
    10/045/2013 10:45:32 - INFO - Current device : MT27i - BX903F3XDK - 1261-8249_R1G - 1254-4241_6.1.1.B.1.54 - WORLD_6.1.1.B.1.54
    10/045/2013 10:45:32 - INFO - Start Flashing
    10/045/2013 10:45:32 - INFO - Processing loader
    10/045/2013 10:45:32 - INFO - Checking header
    10/045/2013 10:45:32 - INFO - Flashing data
    10/045/2013 10:45:33 - INFO - Loader : S1_Root_3065 - Version : R5E006 / Bootloader status : ROOTABLE
    10/045/2013 10:45:33 - INFO - Processing kernel.sin
    10/045/2013 10:45:33 - INFO - Checking header
    10/045/2013 10:45:33 - INFO - Flashing data
    10/045/2013 10:45:36 - INFO - Ending flash session
    10/045/2013 10:45:36 - INFO - Flashing finished.
    10/045/2013 10:45:36 - INFO - Please unplug and start your phone
    10/045/2013 10:45:36 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
    10/045/2013 10:45:36 - INFO - Device connected in flash mode
    10/045/2013 10:45:41 - INFO - Device disconnected
    Questo è il log di flashtool e l'immagine del fw che ho flashato, mi sembra tutto apposto no? ma il telefono comunque non parte, si riavvia sempre alla scritta sony, dammene uno tu se non va bene questo...
  4. #13
    Caserta
    P20 / P10
    Guarda non vedo bene, sto sul cel, ma mi pare che quello che installi è un kernel e non un firmware. Senti quando li hai comprato era legato ad un brand oppure era un no brand. Cerchiamo prima di capire quale firmware dobbiamo installare per rientrare in garanzia
  5. #14
    Fermignano (PU)
    Sony Xperia Sole
    faccio confusione con brand e non brand quindi ti dico che non era associato a nessuna compagnia telefonica...
  6. #15
    Caserta
    P20 / P10
    Nella discussione che ora ti passo ci sono vari firmware e tra questi due italiani. Non è specificato se legati ad un operatore o no. Scarica entrambi e prova. A questo punto però spostati nella discussione di flashtool in sezione generale.
    http://forum.xda-developers.com/showthread.php?t=
  7. #16
    Fermignano (PU)
    Sony Xperia Sole
    marce correggi il link... scusami ma preferisco rimanere qui dato che li dovrei fare un altro post...
  8. #17
    Caserta
    P20 / P10
    Trovi il link corretto nella discussione di flashtool.
  9. Il seguente Utente ha ringraziato marce per il post:
    S0nyXo (10-06-13)
  10. #18
    Fermignano (PU)
    Sony Xperia Sole
    mi puoi linkare la discussione?
  11. #19
    Fermignano (PU)
    Sony Xperia Sole
    si ho installato il fw... ma rimane bloccato nella bootimage xperia... ora??
  12. #20
    Androidiano L'avatar di eth4n
    Ringraziato 48 volte in 38 Posts
    Quote Originariamente inviato da S0nyXo Visualizza il messaggio
    il firmware sarebbe android?? bhe se flasho il file ftf non mi parte android poi... ho flashato ora il .54 in flashmode ovviamente, ma il riavvio continuo persiste non so se mi spiego, si riavvia sempre dato che non ha piu android...
    Io mi domando in tutta onestà per quale motivo mettete mano ai terminali senza saper minimamente nulla di cosa state facendo seguendo le guide un po' alla "membro di segugio", non voglio sminuire nessuno ma sembra di dar in mano una lamborghini ad un neopatentato che sa a malapena accendere l'auto.
    Cmq, fregatene di root, kernel, bootloader ecc, fai il flash di questo firmware GingerBread con FlashTool, una volta fatto lasci riavviare il telefono (anche 2 ore se gli servono le 2 ore) e quando si è avviato lo ricolleghi al pc, installi eventuali driver e se dio vuole lo aggiorni ad ICS.
    Edit:
    Link per GB 2.3.7 per Xperia Sola, versione Europea
  13. Il seguente Utente ha ringraziato eth4n per il post:
    S0nyXo (10-06-13)
