PER-APP-DPI/LAYOUT. This is not tablet mode! Hybrid engine allows you to target apps individually. You get to pick their actual layouts which can tranform content drastically. Keep in mind, this has nothing to do with build.prop hacks or DPI changes. We list all layouts an app brings, you choose one, its as easy as that. It does not matter if your device runs itself in Phone-, Phablet or Tablet-UI, your apps will always look as you like. On top of that you can scale apps, to fit your screen, that way you can even bring full fledged tablet apps and make them run perfectly. Nothing will break, nothing will shrink, your market will be fine. Additionally we have rewritten many parts of the android framework and fixed countless of AOSP bugs to make way for these modifications - our "tablet mode" runs better on a phone than on a real tablet, that is guaranteed.
For UNLOCKED BOOTLOADER only!!
Instruction
Download the ROM here: ParanoidAndroid_XDA_Bruno_kumquat_Alpha_1.zip
Flash the ROM via Recovery
Flash Gapps
Wipe
Reboot,Enjoy
*If your statusbar is gone after the first reboot: longpress Powerbutton > Toggle Statusbar
If you want to Activate Tablet mode go to Settings > Paranoid Settings > Enable tablet UI
Discussione d'origine Download e maggiori informazioni.
