Allora.. Ho flashato il kernel .10... Il temefono si vede tutto scuro ed è praticamente bloccato... faccio binary, ma non mi apre il programma di ripristino... Ti allego quello che compare su binary..
Make a choice: 1
Checking if i should run in Normal Mode or special Sony Mode
Please connect your device with USB-Debugging enabled now
3313 KB/s (210390 bytes in 0.062s)
716 KB/s (4404 bytes in 0.006s)
Found Sony Backup-Restore.apk
LT26,LT22 etc. mode enabled!
Pushing busybox....
3342 KB/s (1085140 bytes in 0.317s)
Pushing su binary ....
3097 KB/s (91980 bytes in 0.029s)
Pushing Superuser app
3310 KB/s (996704 bytes in 0.294s)
Making busybox runable ...
Pushing fake Backup
2249 KB/s (73728 bytes in 0.032s)
Extracting fakebackup on device ...
Watch now your device. Select the backup named RootMe and restore it!
Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.L
AUNCHER] cmp=com.sonyericsson.vendor.backuprestore/.ui.BackupActivity }
Warning: Activity not started, its current task has been brought to the front
If all is successful i will tell you, if not this shell will run forever.
Running ......
EDIT: L'USB debug l'ho attivato
EDIT 2: dopo una decina di tentativi mi si è aperto il ripristino.. provo a continuare
