Ok la PA è difettata , ho un errore stranissimo durante la compilazione che nemmeno percy ha avuto :
codice:
fatal: No annotated tags can describe '161f26dcfb2f9ff69e3ba5457d8074157f1ced33'.
However, there were unannotated tags: try --tags.
find: `src': No such file or directory
build/core/Makefile:40: warning: overriding commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/lib/libril.so'
build/core/base_rules.mk:502: warning: ignoring old commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/lib/libril.so'
build/core/Makefile:40: warning: overriding commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/etc/permissions/android.software.live_wallpaper.xml'
build/core/base_rules.mk:502: warning: ignoring old commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/etc/permissions/android.software.live_wallpaper.xml'
build/core/Makefile:40: warning: overriding commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/lib/egl/egl.cfg'
build/core/base_rules.mk:502: warning: ignoring old commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/lib/egl/egl.cfg'
build/core/Makefile:40: warning: overriding commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/etc/dbus.conf'
system/core/rootdir/Android.mk:35: warning: ignoring old commands for target `/home/leonardo123/PA/out/target/product/kumquat/system/etc/dbus.conf'
PRODUCT_COPY_FILES system/bluetooth/data/audio.conf:system/etc/bluetooth/audio.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/auto_pairing.conf:system/etc/bluetooth/auto_pairing.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/blacklist.conf:system/etc/bluetooth/blacklist.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/input.conf:system/etc/bluetooth/input.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/main.le.conf:system/etc/bluetooth/main.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/network.conf:system/etc/bluetooth/network.conf ignored.
PRODUCT_COPY_FILES system/bluetooth/data/stack.conf:system/etc/bluetooth/stack.conf ignored.
PRODUCT_COPY_FILES device/common/gps/gps.conf_EU_SUPL:system/etc/gps.conf ignored.
No private recovery resources for TARGET_DEVICE kumquat
Docs droiddoc: /home/leonardo123/PA/out/target/common/docs/doc-comment-check
frameworks/base/telephony/java/android/telephony/NeighboringCellInfo.java:104: error 101: Unresolved link/see tag "TelephonyManager#NETWORK_TYPE_DCHSPAP TelephonyManager.NETWORK_TYPE_DCHSPAP" in android.telephony.NeighboringCellInfo
frameworks/base/telephony/java/android/telephony/NeighboringCellInfo.java:166: error 101: Unresolved link/see tag "TelephonyManager#NETWORK_TYPE_DCHSPAP TelephonyManager.NETWORK_TYPE_DCHSPAP" in android.telephony.NeighboringCellInfo
DroidDoc took 165 sec. to write docs to /home/leonardo123/PA/out/target/common/docs/doc-comment-check
make: *** [/home/leonardo123/PA/out/target/common/docs/doc-comment-check-timestamp] Error 45
leonardo123@leonardo-SATELLITE-C850-1G3:~/PA$
