[ROM][OFFICIAL][7.1.2] Paranoid Android - AOSPA [gemini]
    Moderatore SENIOR L'avatar di Fortinho
    Xiaomi Mi 9T
    Ringraziato 3,056 volte in 2,161 Posts
    We’re really excited to announce that we are releasing our Nougat flavour of Paranoid Android. We have a lot in store - with a mix of both features & improvements.
    First & foremost, we have moved our code base to be fully CAF based. This brings many improvements to your device. The key improvement here is that Qualcomm hardware is better tuned on the CAF base and with our additional optimizations we can provide a smooth and fluid user experience that will let you enjoy using your device without any lags.
    On first launch you’ll notice a clean setup with a beautiful wallpaper from Hampus Olsson who’s teamed up with us again and created several beautiful pieces of artwork. For those of you who don’t know, Hampus is a multi-disciplinary artist whose work stands itself and we’re glad to have him onboard. We have also added several new features and made improvements to the UI of the system that we believe would enhance the overall experience.
    Funzioni maggiori:
    Funzioni minori:
    Funzioni specifiche per Mi 5:
    Ottimizzazioni per prestazioni e autonomia specifiche per Mi 5:
    Requisiti:
    DOWNLOAD ROM
    LINK
    Installazione:
    • Provenendo da un'altra ROM
      1. Riavvio in Recovery (Power e Vol+ da spento)
      2. Factory reset
      3. Flash firmware
      4. Flash della ROM
      5. Flash Google Apps
      6. Flash SuperSU (opzionale)
      7. Riavvio
    • Aggiornamento ROM
      2. Wipe cache e dalvik cache
      3. Flash della ROM
      4. Riavvio
    NOTA: i custom kernels sono esplicitamente non supportati e causeranno problemi, a meno che non sia dichiarato che siano compatibili o basati AOSPA!
    fonte
    ►---►---►---►---► REGOLAMENTO --- FAQ FORUM --- CONSIGLI PER NUOVI UTENTI --- BBCODES ◄---◄---◄---◄---◄
    ❗ Chiarimenti versioni ROM MIUI + Link + FAQ + Fondamentali ❗
    Arrow OS - Android 11
    Un grazie è sempre gradito
  2. I seguenti 2 Utenti hanno ringraziato Fortinho per il post:
    BlackJack89 (12-07-17),giarx72 (15-07-17)
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    Uscita la nuova build 7.2.0
    Global Changes:
    • Introducing Pocket lock
    • Introducing Accidental Touch
    • New color modes for Color Engine
    • Option for double tap to sleep on status bar
    • Screen off action for button settings
    • Fix for navigation bar swiping
    • Notification light fixes and improvements
    • Updated PA browser based on M60
    • Pulse on pickup fixed
    • Different fixes for contacts handling and integration into Google apps
    • Various Bluetooth connectivity fixes
    • Improvements for hardware key lighting
    • Higher quality wallpapers
    • Optimized fingerprint unlock speed
    • Fixed reboot to recovery message
    • Various performance enhancements
    • Various power related enhancements
    Ultima modifica di BlackJack89; 14-07-17 alle 09:15
    Un Grazie è sempre ben accetto
  5. Il seguente Utente ha ringraziato BlackJack89 per il post:
    giarx72 (15-07-17)
