crDroid is designed to increase performance and reliability over stock Android for your device also attempting to bringing many of the best features existent today. We're mainly based on LineageOS so use custom kernels compatible with them!
Features
Click for feature list
Always Have a full functional Backup. Just in case!
TWRP Recovery:
Treble TWRP - https://androidfilehost.com/?w=files&flid=262021
DOWNLOAD ROM
DOWNLOAD GAPPS
First time installing crDroid to your Redmi Note 5/Redmi 5 Plus, or coming from another ROM:
** Make sure you're running a proper working Recovery (CWM or TWRP)
1) Copy crDroid zip, gapps zip to your device
2) Boot into Recovery
3) Wipe cache, system, & data (or just cache & system for a dirty flash).
4) Flash ROM
8) Flash gapps
9) Boot up
For root, AFTER you boot into the ROM, you can go back to recovery and install Magisk XX.x (whatever is most recent).
Upgrading from earlier version of crDroid:
The only difference between clean flash as above and upgrading is you just wipe system & cache, leaving data. Everything else is the same. ***Remember to always clean flash before reporting problems. Clean flashing is always the best method of ROM install.
KNOWN ISSUES
You tell me
Don't expect any support if you:
- are not running the included kernel
- have installed any mods such as Xposed!
- have modified system files
Thanks to:
- LineageOS
- SlimRoms
- AOSPA (Paranoid Android)
- OmniRom
- NamelessROM
- Many others... (if you're feeling upset being out of the thanks list just send a PM )
DONATE
crDroid G+ community
Sources
Device Tree - https://github.com/mdeejay/android_device_xiaomi_vince
Kernel - https://gitlab.com/mdeejay/kernel_xiaomi_vince/
ROM - https://github.com/crdroidandroid
Contributors:
@Ruturaj Kadam
@mdeejay
ROM OS Version: 8.1.0 Oreo
ROM Kernel: Linux 3.x
ROM Firmware Required: Unlocked Bootloader & Treble TWRP Recovery
Based On: AOSP
Version Information
Status: Stable
Stable Release Date: 2018-04-11
Created 2018-04-11
Last Updated 2018-04-27
Fonte
https://forum.xda-developers.com/red...-v4-1-t3776326
