AleBerlo
In Needrom è apparsa la Cyanogenmod 12.1, by daniel101, build 2-5-8, da installare via TWRP. Io l'ho installata per testarla, fra una settimana pubblicherò i dati:
http://www.needrom.com/download/cyanogenmod-3/
DESCRIPTION
This is CyanogenMod 12.1 for xiaomi redmi note 2
Change log*Build_5
All sensors working and better strength in IR*signal*
Caller ID*fix
Wifi and Bluetooth fix
General Optimizations
Change log*Build_8
ROM Updated to latest build
IR Plus pre installed
Multi-Language*Added
* Xperia keyboard pre installed
* Latest modem
* MoaAB*pre*installed (adblock)
* Support for lossless audio added (deleted in rom2)
* Camera fix by russian 4pda forum
* Latest Gapps installed
* English language when first install added
* Chinese characters*removed from prop
* Gps optimized for europe
* Rooted with chainfire supersu (It can be deleted*cause you can root with CM*if you know how)
* Ios 9.1 emojis pre installed*
* Xposed pre installed
* Spotify tabletmod pre installed (you need to login manually for it to work, not with facebook)
* Kernel adiutor pre installed
* Nova Launcher pre installed
* F-Droid pre installed
Install:
Download zip file to sd
Reboot to TWRP
Factory reset
Wipe cash
Install zip
done
Enjoy CM!!
Se @
bovirus ritiene opportuno postarla in prima pagina...
