edyros2003
Porting Xperia Z3 V4 for Xiaomi Hongmi WCDMA
V 4.0 UPDATES:
-Xperia recent apps a shake and brush was added. Now if you are able to use at any time, both the xperia small apps.
-Rom material interface
-Audio for improvements were made.
-Improvement works are made for gaming performance.
-Walkman is fixed.
-Sony recently changed versions of the applications.
-Dialer has changed.
-Rom is no theme support.
-No Art support cause incompatibilities with some sony applications
Details and original thread here
http://forum.turkdevs.com/konu-4-4-2...4-0-final.html
download:
https://mega.co.nz/#!mt4QVBTZ!VMy6fL...9IqYHtTzxQ-5Dw
Xperia V3:
Porting della z3 kitkat su Redmi 1
Progetto originale screenshot e maggiori dettagli
XPERIA Z3 V3.0 Kitkat 4.4.2 for MicroMaX Canvas 2+ A110Q (MTK6589) | Custom Android Roms
Caratteristiche Android 4.4 KitKat su Redmi 1 WCDMA (MTK6589)
-Multilanguage
-Android 4.4.2
-Android 4.4.2 Stock Camera con galleria
-Giochi fluidi
-Nuovo Status Bar
-3G su entrambe SIM
-Sim Toolkit
-Init.d Scripts
- Small Apps Xperia (attivabili tenendo premuto per qualche secondo il tasto Home)
E altro.........
Installazione :
Utilizzare recovery custom TWRP o CWM
1) Download della ROM (link sotto)
2) Copiare nella Esterna/Interna SD Card
3) Andare in recovery custom
4) Wipe Data/Factory Reset
5) Wipe Cache
6) Da Advance Menu Delvik Cache Clear
7) Installare da SD
8) Reboot
(Sono necessari circa 5 Min. al primo boot)
Download:
https://mega.co.nz/#!vpgkTSCY!2DELFY...Nxj7QiMoyUztR8
Correzione Bug torcia:
Integrato nella ROM per aggiornare soltanto flashare questo zip
http://goo.gl/T3H5BR
NOTA BENE: Il porting è basato sulle librerie della miui 6 ancora in fase beta e alcuni bug si risolveranno con la versione stabile
Sviluppatore Originale della ROM :-
[4.4.2] *** Xperia? Z3 v3.0 Dr.Razor? *** - TurkDevs.Com Türkiye Android Geli?tiricileri Toplulu?u
(credit : arraki, NeedRom, xda developers, 4pda.net e Swapnil Bunjkar )
