Originariamente inviato da luca_vivi
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JOP40D
ro.build.display.id=GizChina.it rom v1 by Marsapa
ro.build.version.incremental=eng.scm.1378283775
ro.custom.build.version=1378283775
ro.build.version.sdk=17
ro.build.version.codename=REL
ro.build.version.release=4.2.1
ro.build.date=Wed Sep 4 16:37:45 CST 2013
ro.build.date.utc=1378283865
ro.build.type=user
ro.build.user=scm
ro.build.host=vanzo66
ro.build.tags=test-keys
ro.product.model=ZP9990
ro.product.brand=ZOPO
ro.product.name=V7
ro.product.device=V7
ro.product.board=V7
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=ZWX
ro.product.locale.language=it
ro.product.locale.region=IT
ro.wifi.channels=
ro.board.platform=MT89_V7
# ro.build.product is obsolete; use ro.product.device
ro.build.product=V7
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=V7-user 4.2.1 JOP40D eng.scm.1378283775 test-keys
ro.build.fingerprint=ZOPO/V7/V7:4.2.1/JOP40D/1378283775:user/test-keys
ro.build.flavor=mt89_v7_zp9700w_zwx_jb2_hw
ro.build.characteristics=default
# end build properties
# begin mediatek build properties
ro.mediatek.version.release=ALPS.JB2.MP.V1.3
ro.mediatek.platform=MT6589
ro.mediatek.chip_ver=S01
ro.mediatek.version.branch=ALPS.JB2.MP
ro.mediatek.version.sdk=1
# end mediatek build properties
# system.prop for generic sdk
rild.libpath=/system/lib/mtk-ril.so
rild.libargs=-d /dev/ttyC0
# MTK, Infinity, 20090720 {
wifi.interface=wlan0
# MTK, Infinity, 20090720 }
# MTK, mtk03034, 20101210 {
ro.mediatek.wlan.wsc=1
# MTK, mtk03034 20101210}
# MTK, mtk03034, 20110318 {
ro.mediatek.wlan.p2p=1
# MTK, mtk03034 20110318}
# MTK, mtk03034, 20101213 {
mediatek.wlan.ctia=0
# MTK, mtk03034 20101213}
wifi.tethering.interface=ap0
ro.opengles.version=131072
wifi.direct.interface=p2p0
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.heapsize=256m
# USB MTP WHQL
ro.sys.usb.mtp.whql.enable=0
# Power off opt in IPO
sys.ipo.pwrdncap=2
ro.sys.usb.storage.type=mtp,mass_storage
# USB BICR function
ro.sys.usb.bicr=yes
# USB Charge only function
ro.sys.usb.charging.only=yes
# audio
ro.camera.sound.forced=0
ro.audio.silent=0
ro.zygote.preload.enable=0
# ADDITIONAL_BUILD_PROPERTIES
ril.specific.sm_cause=0
gps.solution.combo.chip=1
ril.external.md=0
fmradio.driver.chip=3
ro.sf.hwrotation=0
ril.current.share_modem=2
launcherplus.allappsgrid=2d
launcher2.allappsgrid=3d_20
curlockscreen=1
ro.mediatek.gemini_support=true
persist.radio.fd.counter=15
persist.radio.fd.off.counter=5
persist.radio.fd.r8.counter=15
persist.radio.fd.off.r8.counter=5
persist.mtk.wcn.combo.chipid=-1
drm.service.enabled=true
fmradio.driver.enable=1
ril.first.md=1
ril.flightmode.poweroffMD=1
ril.telephony.mode=1
ril.radiooff.poweroffMD=0
dalvik.vm.mtk-stack-trace-file=/data/anr/mtk_traces.txt
mediatek.wlan.chip=MT6628
mediatek.wlan.module.postfix=_mt6628
ro.config.notification_sound=pop.ogg
ro.config.alarm_alert=Alarm_Beep_03.ogg
ro.config.ringtone=Orion.ogg
qemu.hw.mainkeys=1
ro.init.screen_brightness=255
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
# begin adupsfota properties
ro.adups.fota.oem=Vanzo
ro.adups.fota.device=ZP990
ro.adups.fota.version=ZP990 20130904-163745
dalvik.vm.checkjni=false
dalvik.vm.verify-bytecode=false
dalvik.vm.dexopt-flags=
ro.kernel.android.checkjni=0
ro.kernel.checkjni=0
debug.sf.hw=1
debug.egl.profiler=1
debug.egl.hw=1
debug.composition.type=gpu
video.accelerate.hw=1
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
ro.media.capture.maxres=8m
ro.media.panorama.defres=3264x1840
ro.media.panorama.frameres=1280x720
ro.camcorder.videoModes=true
ro.media.enc.hprof.vid.fps=65
ro.media.enc.jpeg.quality=100
ro.media.capture.flash=led
ro.media.capture.flashMinV=3300000
ro.media.capture.torchIntensity=65
ro.media.capture.flashIntensity=70
Dalvik.vm.execution-mode=int:fast
persist.sys.use_dithering=0
debug.performance.tuning=1
pm.sleep_mode=1
persist.sys.purgeable_assets=1
ro.ril.disable.power.collapse=1
wifi.supplicant_scan_interval=100
ro.mot.eri.losalert.delay=1000
windowsmgr.max_events_per_sec=300
ro.max.fling_velocity=12000
ro.min.fling_velocity=8000
ro.HOME_APP_ADJ=1
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960 net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960 net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960 net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960 net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
mot.proximity.delay=25
ro.lge.proximity.delay=25
### Pimp my Rom : xLoud & ClearAudio+
ro.semc.sound_effects_enabled=true
ro.semc.xloud.supported=true
persist.service.xloud.enable=1
ro.semc.enhance.supported=true
persist.service.enhance.enable=1
ro.semc.clearaudio.supported=true
persist.service.clearaudio.enable=1
ro.sony.walkman.logger=1
persist.service.walkman.enable=1
ro.somc.clearphase.supported=true
persist.service.clearphase.enable=1
Inviato dal mio ZP9990 usando Androidiani App
luca_vivi (30-09-13)
Vedo che hai aggiunto anche la stringa del GPS
LeEco Le MAX 2
Rom: AICP 8.1.0
Kernel:
Ciao a tutti
Mi state aprendo un mondo...
Io mi occupo di ingegneria meccanica, ma voi, andate oltre al mio immaginario, ragazzi vi stimo !
Scusa Dario non comprendo....cos'e' che vuoi sapere?
Le due apps servono per aggiornare il firmware tramite un sistema chiamato OTA=On THE AIR ....cioe' un pacchetto di aggiornamento (non completo perche' sarebbero parecchi Mb.)lanciato dai server Zopo per l'aggiornamento di un firmware piu' vecchio ad una versione piu' nuova!
Per quanto riguarda il messaggio che ti da....ti fa capire che hai l'ultimo installato!
Ora non ho capito se desideravi sapere questo?
Formulami meglio la domanda!
ciao
Ciao Ghost45, ne approfitto io per chiederti una cosa, funziona l'aggiornamento OTA? Credo di no, perché io ho ancora il firmware di agosto, ma se faccio la ricerca di un aggiornamento disponibile mi viene restituito sistema aggiornato anche se non è vero...
Ciao Tanemina,
Questo aggiornamento non e' ancora stato fatto su OTA....quindi non e' un problema sul funzionamento.
E' giusto che ti dica aggiornato....perche' ancora non c'e' !
Ma poi se verifichi sulle pagine Uffiiciali questo aggiornamento non esiste ancora neanche tra i download!
E' stato dato in anticipo proprio per la favorire la gestione della flip cover.
ciao
Ultima modifica di ghost45; 30-09-13 alle 19:36
Perfetto, grazie.
