guarda qualche post piú sopra.. il #13 per l'esattezza..!
bene... però prima di svalvolare tutto ti chiedo conferma :)
>No, you have to flash it through RSD Lite (5.3.1 I'd suggest).
00 - devo usare il programma RSD
>Here is a how to:
>0. Charge fully your battery before starting to flash!
0 - caricare tutta la batteria
>1. DL DEFYPLUS_U3_4.5.1-134_DFP sbf file.
1 - scaricare questo file... non sono un esperto potresti darmi un link?
>2. DL firmware and firmware.z01, put them in the same folder and extract firmware - it will create a firmware folder inside your current folder with another SBF file inside.
stesso problemino... dove li trovo questi due files?
e quello che c'è dentro lo estraggo nella stessa cartella del file di prima
praticamente ho una cartella con 2 file sbf???
>3. DL and install Motorola usb drivers, so your phone gets recognized by the PC in bootloader mode.
>4. Install RSD Lite 5.3.1
3 e 4 ok
>5. Get your phone into BL mode - turn it off, press and hold Vol+ and Pwr button. This is what your screen should look like:
5 - bene
>6. Start RSD Lite as Administrator and connct your phone to PC
>7. Press the "..." button in RSD lite and select the DEFYPLUS_U3_4.5.1-134_DFP file. Hit start, sit back and wait.
6-7 lancio rsd e selezione il primo file sbf
>8. DO NOT TOUCH, TURN OFF, UNPLUG your phone untill the flash process is complete or you can permanently brick your phone!
sto fermino fino a che non ha finito
>9. Repeat steps 7 and 8, but this time select the second sbf file that was exctracted from the firmware zip's in the firmware folder.
rifaccio la stessa cosa con il secondo file (estratto da firmware.zip)
praticamente faccio il flash due volte? ma il secondo non sale sopra al primo?
>10. After flashing is done, turn off the phone, unplug it from the PC, press and hold Vol- and Pwr buttons. At the yellow exclamation mark with an android press simultaneously Vol+ and Vol-
>11. Wipe data/factory reset.
10-11 bene ripulisco tutto
>Reboot and enjoy your newly rooted BL7 Defy+ (and don't forget to send me a beer )
a questo punto visto che non posso inviarti una birra me la bevo io alla tua salute?
grazie mille
ciao :)
il messaggio linkato dal nostro gentilissimo compagno di forum è parte di un thread sull'argomento, questo [success!]defy bl7 root! - xda-developers dove troverai tutte le info richieste e i link (diversi) per i file da scaricare!
ciao, valeria
Io vorrei provare per il defy+ Superoneclick, ma l'antivirus mi trova un exploit ed un trojan, e non mi fido proprio.
Ho visto che anche con Visionary+ si può rootare il tel, ma non so se funziona sul defy+.
Avete provato?
ciao a tutti, ho seguito questa guida, ma quando o flashato le due seconde parti, RSD mi da 'pass' e il telefono si blocca nella schermata di avvio con i seguenti errori Err:A5,69,35,00,27 ...riprovato, con altri file non cambia nulla, il problema è che riportando il telefono con le impostazioni di fabbrica ho perso tutte le app.
nel senso...le avevo backuppate con easy back up, i contatti e messaggi me li ha recuperati, le app no...ok le reinstallo da play ma non è il massimo, quindi...avete soluzioni a ciò? grazie
