Vi segnalo l uscita della cyano 9 per xoom..
Per installare la rom bisogna avere una recovery modificata (rogue 1.3.0)
Includes:
+Source from CyanogenMod 9 (1/9/12)
+Full support for Camera, HDMI and Video acceleration (from the leaked 4.0.3 ROM)
+Rogue XM Kernel 2.0.2
+Disabled lockscreen rotation
+Allow apps to write to SD card (thanks kcrudup)
+Tweaked ICS boot animation (thanks Sardo Numspa)
Install Instructions-
-Make a backup in your current recovery
-Download zip's from link's below
-Place zip's on external sdcard (change file extension's to .zip if listed as .php)
-Boot into recovery and wipe: data, cache, and dalvik cache
*Upgrading between builds should only require wiping caches unless otherwise noted
-Install Rom
-Install Gapps(recommended Gapps linked below)
-Reboot
-Enjoy the glory!
In parole poche:
Mettere lo zip della rom nella sd esterna,fare un backup da recovery (non si sa mai ),fare tutti i wipe ( data, cache, and dalvik cache ),installare la rom e poi le gapps
Download-
Rom-
http://api.viglink.com/api/click?for...13273174962791
Gapps-
goo-inside.me - Gapps downloads
-Partial Changelog-
1/22/12 (Rom)
Rom-
*Fixed lag when toggle switches in quick settings (wifi, bluetooth)
1/19/12 (Rom)
Rom-
+New Quick Settings switches (WIP)(replaces Notification Power Widget)
*Tapping Wi-Fi/Bluetooth/GPS will open the appropriate Settings screen
+Updates to prebuilt ROM Manager, Terminal Emulator
1/18/12 (Gapps)
Gapps-
*Fixed installer script leaving duplicate Search apps
Rom-1/16/12 (Rom)
+Enabled Notification Power Widget (thanks bazar6)
**Known issue, GPS icon does not highlight unless you close and re-open window
Rom-1/15/12 (Rom)
*Trebuchet: Fixed app drawer icon disappearing when removing search bar
*Rogue: Fixed broken cifs.ko
1/13/12 (Rom, Gapps)
***Full wipe is not required for Rom and Gapps update (unless your coming from another Rom), but it is recommended***
Rom-
*Rebased binaries on IML77 OTA (libs, apks, bootanimation)
+Enabled reboot menu (thanks NPerry)
Gapps (v5.1)-
+Rebased on GApps from the IML77 OTA
+Removed portrait only setup in FaceLock.apk
*Updated versions of Market and Maps
1/12/12 (Rom, Gapps)
***If you are on a prior CM build, only a cache and dalvik cache wipe is needed***
Rom-
+Added face unlock support (thanks solarnz and LPHS) *Requres latest GApps
+Auto-rotate switch now controls lockscreen rotation
Gapps (v4)-
+Replaced YoutubeTablet.apk with the regular 4.0.3 Youtube.apk
*Renamed Gallery (fix duplicate gallery appearing)
+Added face unlock files
+Added Superuser.apk from market
1/11/12 (Rom)
Rom-
*Trebuchet: Removing the Search bar no longer force closes Trebuchet (known issue: removing the search bar also removes the app drawer icon)
*Trebuchet: More suitable defaults on first boot (centered clock, auto rotation)
Kernel-
+Rogue XM Kernel 2.0.2: BogoMIPS now scales with frequency, both cores
1/10/12 (Gapps)
Gapps (v3)-
+Fixed issue with G-Talk video
+Fixed issue with sillyfaces
*If you are on a prior CM9 build we recommend a full wipe due to the updated Gapps.
1/9/12 (Rom, Gapps)
Rom differences from upstream-
Kernel-
+Rogue XM Kernel 2.0.1 (CPU and GPU OC, voltage control, init.d, USB OTG, CIFS, TUN)
+Based on Google/Motorola's 2.6.39.4 kernel for Android 4.0
+Storage controller tweaks (thanks kcrudup)
+Cache controller tweaks
+filesystem tweaks
Thank You-
CyanogenMod Team
Kejar
NPerry
Kcrudup
Team Eos
