è uscita la #110 x il changelog aspettiamo Gyn
[CyanogenMod 10.1 Nightly JB 4.2.1]
No... mi sto godendo la Codename 3.4.0 uscita anch'essa ora.. fanno a gara??
Inserita di default modalità SMS
Changes
Implement On-The-Fly real time grouper tablet/phone mode change (3 of 3)
Change-Id: I9c09c94ddc8084e0897dda8c2d68e223e8843f16
-- Randall Rushing / detail
grouper: power hal: Don't overwrite a user set maximum cpu frequency on display off.
Change-Id: I2580549bfb516a1df6d64d3efa0be83d92b4d16d
-- Chris Trotman / detail
Add sms support for umts_everest
Change-Id: I4c2ef055e93c1707c07972e5f74431579e07f626
wingray common: remove --fast-math compiler option
This was the source of the "NetFlix/FaceBook/Play Magazines" issue
Change-Id: I4e7cf97eb626a5c9627128de22a40dfa72d6bfb6
-- Kenneth R. Crudup / detail
Merge "bring in improved gps.conf from toro" into jellybean
Update SprintDiagnostics system app for toroplus
-- implemented usb diagnostics mode
-- acquire msl no longer depends on modded HiddenMenu.apk
-- removed unnecessary preferences and cleaned up strings
Change-Id: I49ccf3508add40787dfa9755c07d426b09c4f0b0
tuna: power: Save the maximum screen on frequency so we can restore it.
This fixes the issue of the device resetting to a 1.2GHz clock speed
after the display turns off and back on.
Change-Id: I08da0d96f03f824fe888a29215a3d12229126aeb
Implement On-The-Fly real time grouper tablet/phone mode change (1 of 3)
Change-Id: Ib9cf6210c566c86ec1af8456c397332326447310
Implement On-The-Fly real time grouper tablet/phone mode change (2 of 3)
Change-Id: Ifd2c22c89ee8e164493953c0101bd8a31132d03f
Revert "(Toroplus) Add modded apk to assist with device settings apk"
This reverts commit dae509f4b4a47bcd1b923b09d1c4274c3825fdb5.
Come ti trovi meglio? Codename o team EOS?
Inviato dal mio MZ601 con Tapatalk 2
«L’anti-intellettualismo è stato un costante tarlo che si è insinuato nella nostra vita politica e culturale, nutrito dall’idea sbagliata che democrazia significhi che la nostra ignoranza valga quanto l’altrui conoscenza».
Isaac Asimov
Sono entrambe valide.. però ci voleva questo stimolo del nome in codice.. per muovere l'interesse sulla monopolista EOS..
Edit..
Tornato a eos..
Funzione sms implementata nel sistema
Ultima modifica di Gynlemon; 28-08-12 alle 14:33
Gyn potresti darmi quelle dritta sul governor
Inviato dal mio MZ601 usando Androidiani App
Interactive lascia.. oppure se noti lag setta lagfree
Ottimo, questi giorni pro vero la 109 molto meglio rispetto gli aggiornamenti ufficiali
guarda che è uscita la #110 hai visto un paio di post su?
Sisi ho visto un po su però prima di metterla vorrei sapere se funziona tutto cm al solito
