aggiornato il post dei temi
aggiunto quello standard con la modifica automount che han chiesto su xda
gyn se voi wippare i workinprogress copiarlo nel primo post qui ... per me ok diventa piu conciso e chiaro
(e i prox giorni riprovo x il nexus)
Xoom : team eos 4
Maguro : VanirAOSP 4.4.4 ART F2FS / TWRP 2.7.1.1 f2fs / SmittyV-UR-NoMeM
Prova a vedere ora..
2.3 !!
dicono che abbia l automount ...
Goo.im Downloads - Browsing wingray
Xoom : team eos 4
La mount subito!! addirittura personalizzata ? hemm .img?
cosi faccio ...2 test..ate...
prendi il file .zip della 2.2.2.0 , apri con winrar o 7zip (gli altri fan danni) rinomini il scaricato per sovrascrivere il recovery.img del .zip
ora flasho, se sparisco ...so xxi
edit fatto, mi son dimenticato che ho il mio tema installato quindi non ho idea delle differenze :-)
edit 2:
CHANGELOG for 2.3.0.0:
-Rebased onto AOSP Jelly Bean source code
-Rewrote backup, restore, wipe, and mount code in C++ classes for easier maintenance going forward
NOTE: backups from prior versions of TWRP are still compatible with 2.3
-ADB sideload functionality from AOSP is included in 2.3, see this link for more info
-Re-wrote fix permissions entirely in C++ and runs in a few seconds instead of a few minutes (thanks to bigbiff)
-Improvements to zip finding in OpenRecoveryScript (should be a lot fewer GooManager automation issues)
-Faster boot times
-Added charging indicator while in recovery (only updates once every 60 seconds)
While this update may not bring a host of new must-have features, this update is a significant re-write of much of the core TWRP code. AOSP Jelly Bean recovery source moved to mostly C++ code and now all of the "TWRP" code is fully rewritten into C++ as well. Now that we've laid this groundwork, we're in a much better position to pull in future AOSP recovery updates as well as implementing more great new features.
Since TWRP 2.3 is based on AOSP jelly bean sources, TWRP now uses recovery API 3 instead of 2. Some zips may no longer work if the developer is using an out-of-date update-binary. This API change should not be a problem on newer devices, but older devices will probably encounter several zips that need to be updated. If needed, you can try using this update-binary that was compiled with current sources. It goes in your zip file in the META-INF/com/google/android folder.
http://www.teamw.in/project/twrp2
Ultima modifica di Nemis; 11-10-12 alle 23:15
Xoom : team eos 4
Flashata l'immagine tramite emulatore terminale. Ora installo un tema, ho visto alcuni carini ma sono per il one x.
Ultima modifica di manudroide; 12-10-12 alle 03:29
Ma guarda che goo manager la installa in automatico, basta andare in menu>install openrecoveryscrip e fa tutto lui. La trova, la scarica e la installa....
Sti cervelloni sempre a cercà le strade più difficili....
Comunque la cosa che ho verificato subito è che monta in automatico anche sd...
Inviato dal mio MZ601
Motorola Moto X Force XT1580 STOCK
Nokia 8 TA-1012 STOCK
ASUS ZENPAD 10 P01T STOCK
Nemis (12-10-12)
Io ho fatto tutto da cell acceso senza spegnerlo. Basta rinominare il file in recovery.img e spostarlo in sdcard, aprire emulatore terminale e dare il comando:
Su (dare invio e poi dare il comando successivo)
dd if=/sdcard/recovery.img of=/dev/block/platform/omap/omap_hsmmc.0/by-name/recovery
Fatto riavviate e godetevi la recovery.
Ultima modifica di manudroide; 12-10-12 alle 14:49
