Con le nuove ROM con 4.2 devi per forza mettere le nuove recovery .. se metti la nuova 2.3.3.0 il mount non c'è più bisogno di farlo , lo ha settatp di default
## REGOLAMENTO FORUM ##Prima di postare , date un'occhio sempre alla prima pagina e ai 3D in Rilievo...
xmas43 (13-01-13)
Ok installata, ora mi vede la la internal che prima non vedeva.
Ultima modifica di xmas43; 13-01-13 a 11:42
Samsung S2 Blumak2000 4.1.2
Motorola Xoom 3g Team Eos4 4.2
Vodafone Ideos cyanogen mod 7
Rilasciata la 2.4.0.0
Inviato dal mio Xoom con Tapatalk 2
Motorola Atrix MB860 [Jelly Bean 4.2.2 - CyanogenMod 10.1 - Recovery TWRP 2.5.0.0]
Motorola Xoom MZ601 [Jelly Bean 4.2.2 - CyanogenMod 10.1 - Recovery TWRP 2.5.0.0]
Scusate, ma per Xoom l'app Goo non scarica la 2.4.0 in automatico (come invece avviene su Nexus), sapete dove si può reperire? Grazie
Grande! Grazie mille.
Ultima modifica di Gynlemon; 31-01-13 a 14:59
CHANGELOG for 2.4.1.0:
Fixed a problem with mkdosfs that formatted sdcards to 2GB
Fixed handoff between vfat and exFAT on devices where blkid didn't detect vfat (fixes some issues with mounting sdcards)
Fixed problems with changing working directory on MD5 creation/checking that may have prevented unmounting
Backups will now store a copy of the backup log after the backup is completed (only if backup is successful)
Flashable .zip http://d-h.st/a9W
Uscita 2.4.2.0 Goo.im Downloads - Browsing wingray
Changelog 2.4.2.0:
Add screen timeout - screen will turn off automatically after 60 seconds, saves battery and prevents screen burn-in especially on AMOLED devices
Add a brightness setting (requires device specific setup and only some devices have been added)
Add a root checker and offer to install SuperSU if the device isn't already rooted
Add a write buffer to libtar backups, significant improvements to speeds when backing up to exFAT target, minor improvements for other file systems
Check and offer to fix root permissions if broken
Add an option for a 24 hour clock display instead of AM/PM (aka military time)
Move stock recovery reflash check to occur during the reboot cycle
Add support for some MTK6xxx devices
Change libtar to vfork to help prevent memory problems
Add a "clicked" effect to most buttons, file selector, and listbox
Improve timezone listbox to be more like file selector (per pixel kinetic scrolling, etc)
Remove some no longer used settings (For
