theplague1977
Ciao a tutti, scusate se mi intrometto, qualche mese fa anche io ho riportato il mio Xoom MZ601 allo stato originale, ho usato RDS per effettuare il flash dell'immagine, però ho confrontato la guida di Gynlemon con un'altra in lingua inglese che adesso non trovo più, e la differenza che ho riscontrato tra quella presente in questo Thread e l'altra è una solta, ovvero quella di riavviare lo xoom in RDS mode prima di procedere al flash, io ho seguito le due guide e ho riportato il mio xoom alla 4.0.4 originale.
Se trovo la guida ve la posto.
Trovata:
Getting Back to Stock
You will need:
Fast boot software but if you already rooted you should have it
The latest Motorola USB drivers. Download here
RSDlite Software installed with Admin privileges. Here is a link that is currently working. (rar password alabama)
The correct SBF downloaded and extracted. When I say correct I mean you are going to have to check the build number and model of your Xoom. Loading a WiFi Xoom SBF on a 4G model would be “all bad” and vice-versa. Here is a link to the most recent 3G/4G one I know of. I do not have a link to the WiFi SBF as of yet. Note: For reasons beyond me Verizon and Motorola do not like users to be able to reset their own devices, so you may have to hunt RSDlite and or the SBF down.
Flashing the SBF:
Run RSD Lite as Admin
Power off your Xoom, press volume up and power at the same time until the device starts. It should boot with "Starting RSD protocol support 3"
Connect your supplied USB cable (I say supplied because 3rd party cables can cause issues)
Browse to the SBF file you extracted in the filename box (use the ... button to select)
Click on Port 1 and select Show Device. If it looks similar to the below image (Device and File Properties are both populated) you are all set
Click Run
Allegato 72679
