[Recovery] CWM ClockworkMod
    Banned
    ClockworkMod 5.0.2.8 Based
    -Rogue Recovery 1.5.0 (RC3)
    Installazione :
    -Scarica il file zip dal link sottostante
    -Copiare lo zip Micro SDcard
    -Riavviare in recovery esistente
    -Scegliere install zip e selezionare il Rogue Recovery
    -Conferma file, attendere che finisca di Flashare , quindi riavviare
    -Riavviare di nuovo in Recovery e godersi la recovery Rogue!
    Download : 1.5.0 (RC3)
    +Updated base to CWR 5.0.2.8
    +Full touch support
    **touch menu selections, use on screen buttons, or use volume rockers and power button
    ***swipe cursor movement (swipe left or right to go back)
    +New CM style blue theme
    +Large Roboto font
    *Fixed text flow
    +Changed menu style and layout
    +Large backups (>2.1GB) should work now
    *Note: 4GB FAT32 limit still applies
    +Updated kernel , busybox
    +UMS supported
    +Fixed script assert toggle (thanks Sam Mortimer)
    -Removed backup internal storage (buggy, storage limits)
    -Removed partition storage (dangerous)
    Ultima modifica di Gynlemon; 03-02-13 alle 18:59
  2. I seguenti 2 Utenti hanno ringraziato Gynlemon per il post:
    il tiny (16-03-13),jurik (21-09-12)
    Banned
    [Recovery] ClockworkMod Touch Recovery 6.0.2.3
    New ClockworkMod Recovery fixes the problem that factory reset on Android 4.2 always lead to migration content of /sdcard to /sdcard/0. This is built from ClockworkMod Recovery Builder and can be used on Xoom. There may be some problems with Hong Kong & Taiwan UMTS variation due to different partition layout, but it is fine if you don't flash from internal storage.
    Downloads
    ClockworkMod Touch Recovery 6.0.2.3 (Flashable Zip)
    recovery-clockwork-touch-6.0.2.3-wingray-signed.zip
    MD5: 6ffa033a8e41749924358f3c753c62af
    SHA1: 79a4c3ca1350b34c01afbb26ef90bfc4bd4bbdc9
    ClockworkMod Touch Recovery 6.0.2.3 (Image)
    recovery-clockwork-touch-6.0.2.3-wingray.img
    MD5: 09ae5c6c616d2f22f030d22951da2662
    SHA1: 5454bfe3d33a4e5eb8c51bf7c86f64aea69d8e34
    ClockworkMod Recovery 6.0.2.3 (Flashable Zip)
    recovery-clockwork-6.0.2.3-wingray-singed.zip
    MD5: 3bf41f0716d584a09fdd3ba97a12203d
    SHA1: 493e543483afc6649f8258ef91ca00f11cd87383
    ClockworkMod Recovery 6.0.2.3 (Image)
    recovery-clockwork-6.0.2.3-wingray.img
    MD5: 17426ea6feb6ff50ad00982c92b1834b
    SHA1: e59dd702bd19ac60963650813fea6811413638d5
  5. Il seguente Utente ha ringraziato Gynlemon per il post:
    il tiny (16-03-13)
  6. #3
    Banned
  7. Il seguente Utente ha ringraziato Gynlemon per il post:
    il tiny (16-03-13)
