ops, 3.56...avevo solo sbagliato a scrivere, adesso l'ho corretto
grazie della segnalazione
pesa1234 (07-09-15)
hallo....so i have to wipe: cache, dalvikcache and system?
or cache, dalvikcache and data?
and can i wipe wipe internal storage too?->for real clean install?
system now is cm12.1v10
Mirakulixs (09-09-15)
hallo
thx Paolo
i will make it on friday.
your roms and help are very nice and helpfull from you and so the z7max is a great phone, cause people like you make custom roms!!!!
regards
24hours after flash - this rom feels smoother and better like your cm rom.
all features are working perfect, infrared, dualsim, wifishare, etc....
and on antutu i have now 45k points, around 7k more like cm12.1.
thanks for this great work!
regards
Ultima modifica di Mirakulixs; 12-09-15 alle 11:36
I'm on V2.
I have an issue with ringtone and notification volume. it is very low.
I've tried to cancel AudioFX and change sound but it is still very low.
The strange thing is that some times for a short while after I play with the volume the volume is ok and them low again.
Ultima modifica di bull123; 15-09-15 alle 19:24
Thx a lot for your rom.I notice that carbonrom had stopped updating in recent two versions.
I have use carbonrom for about a month and love it very much.
And i wonder whether it will update again?
Thanks.
ciao è possibile porting per z7 mini?
gieffe16 (25-09-15)
