Pagina 42 di 43 primaprima ... 3240414243 ultimoultimo
Visualizzazione dei risultati da 411 a 420 su 423
Guida all' installazione della Rom Cyanogenmod 7.0.3 Gingerbread
  1. #411
    Androidiano L'avatar di kev81
    Catania
    LG G3
    Quote Originariamente inviato da alekim91 Visualizza il messaggio
    allora avevo l'ultima rom che mi avete consigliato...
    adesso ho cliccato su download.bat
    e mi esce questo
    C:\Users\Administrator\Desktop\233>"nvflash.exe" --bct flash.bct --setbct --bl b
    ootloader.bin --configfile flash.cfg --odmdata 0xba0c0011 --create --go
    Nvflash started
    rcm version 0X20001
    System Information:
    chip name: t20
    chip id: 0x20 major: 1 minor: 3
    chip sku: 0x8
    chip uid: 0x17144044420185d7
    macrovision: disabled
    hdcp: enabled
    sbk burned: false
    dk burned: false
    boot device: nand
    operating mode: 3
    device config strap: 0
    device config fuse: 0
    sdram config strap: 0
    sending file: flash.bct
    - 4080/4080 bytes sent
    flash.bct sent successfully
    odm data: 0xba0c0011
    downloading bootloader -- load address: 0x108000 entry point: 0x108000
    sending file: bootloader.bin
    | 941356/941356 bytes sent
    bootloader.bin sent successfully
    waiting for bootloader to initialize
    bootloader downloaded successfully
    setting device: 1 0
    creating partition: BCT
    creating partition: PT
    creating partition: EBT
    creating partition: MBT
    creating partition: BLO
    creating partition: MSC
    creating partition: OGO
    creating partition: SOS
    creating partition: LNX
    creating partition: APP
    creating partition: CAC
    Formatting partition 2 BCT please wait.. done!
    Formatting partition 3 PT please wait.. done!
    Formatting partition 4 EBT please wait.. done!
    Formatting partition 5 MBT please wait.. done!
    Formatting partition 6 BLO please wait.. done!
    Formatting partition 7 MSC please wait.. done!
    Formatting partition 8 OGO please wait.. done!
    Formatting partition 9 SOS please wait.. done!
    Formatting partition 10 LNX please wait.. done!
    Formatting partition 11 APP please wait.. done!
    Formatting partition 12 CAC please wait.. done!
    done!
    sending file: mbtdata.img
    - 1024/1024 bytes sent
    mbtdata.img sent successfully
    sending file: boot.bmp
    - 1843254/1843254 bytes sent
    boot.bmp sent successfully
    sending file: logodata.img
    \ 2177472/2177472 bytes sent
    logodata.img sent successfully
    sending file: recovery.img
    | 3569664/3569664 bytes sent
    recovery.img sent successfully
    sending file: boot.img
    \ 2443264/2443264 bytes sent
    boot.img sent successfully
    sending file: system.img
    | 139341312/139341312 bytes sent
    system.img sent successfully
    C:\Users\Administrator\Desktop\233>pause
    Premere un tasto per continuare . . .
    si inchioda sempre su ciano...
    lo vendo...
    Adesso lo spegni, entri in recovery e fai i wipe che ti ho detto prima. Riavvii e dovrebbe funzionare.
    Senior Droid L'avatar di dodimatto
    Ringraziato 63 volte in 48 Posts
    Quote Originariamente inviato da kev81 Visualizza il messaggio
    Prova ad effettuare i wipe di data, cache e riavvii.
    anche a me rimaneva inchiodato sulla freccia della cm7
    ma, come consigliato
    ho riavviato (vol+ e power)
    ho fatto i wipe (data e cache)
    ho riavviato (reboot)
    e magicamente è partito, finalmente
    grazie a tutti
    se vi sono stato utile e volete ringraziare utilizzate per favore il tasto sulla sinistra sotto il mio avatar
  4. #413
    Ringraziato 101 volte in 70 Posts
    Qualsiasi Rom metto la procedura va a buon fine...ma dopo non si accende più...potreste aiutarmi ?? Grazie...
  5. #414
    non riesco a scaricare le google apps, mi date una mano?
  6. #415
    Quote Originariamente inviato da William990 Visualizza il messaggio
    salve william hai risolto? anch'io ho lo stesso problema con schermo nero
  7. #416
    Sep 2013
    Quote Originariamente inviato da beomondo Visualizza il messaggio
    stesso problema
  8. #417
    Qualcuno sa dove posso trovare i Driver per l'APX?
  9. #418
    Ciao volevo sapere se questa guida è valida anche per olipad3. Grazie
    Quote Originariamente inviato da andromaxnet Visualizza il messaggio
    Ripristinate la rom come era in origine.
    1) Scaricate la seguente rom cyanogenmod7
    2) Scompattatela
    3) Mettere l' Olipad in modalita flash (come: da spento premere tasto accensione insieme al tasto volume "-" )
    4) Collegatelo al pc con un cavo USB (se chiede di installare i driver scaricateli e installateli da qui) quindi vi troverà una nuova periferica
    5) Entrate nel prompt dei comandi del "DOS" e andate nella cartella della rom scompattata in precedenza e lanciate il file download.bat
    6) Comincerà la procedura di flash che terminerà in poco tempo a questo punto si riavvierà con la nuova rom (Vi consiglio di tenere una sim dentro alla slot per evitare problemi con la lingua al primo riavvio)
    7) Installare le google apps e Market scaricando il file zip da qua
    8) Copiatelo nella memoria "interna" dell' olipad
    9) Entrate in modalita Recovery (come: da spento premere tasto accensione insieme al tasto volume "+" )
    10) Scegliete la voce: "install zip from sdcard" e poi "choose zip from sdcard"
    e poi selezionate il file zip scaricato delle google apps
    11) Fate il Reboot, al riavvio dell' Olipad avete tutto quello che serve incluso modulo GSM e 1GB di ram.
    Fine prima Parte
    12) Aggiornamento alla 7.0.3
    13) Ora scaricatevi questo
    14) Copiate il file nella memoria interna dell' olipad
    15) Entrate in Recovery
    16) Scegliete la voce: "install zip from sdcard" e poi "choose zip from sdcard"
    e poi selezionate il file zip dell' aggiornamento alla 7.0.3
    17) Fate il Reboot, al riavvio dell' Olipad avete tutto Accelerazione hardware supportata nella riproduzione dei video di (youtube 720 ed mkv) e fluidita e velocita generale.
    Fine
    Un grazie speciale a "makenmake" e "arthas85"
    Note:
    Se vi si presentasse errori nel caricamento dei widgets all'avvio si puo' risolvere cosi:
    Con root explorer cancellate deskclock.apk dalla cartella system/apps
    e poi togliete il blocco dello schermo (impostazioni/posizione protezione/imposta blocco schermo/nessun blocco..)
    Per i più coraggiosi.
    Per chi vuole cambiare il kernal per avere maggiore velocità e passare a 1.400GHZ
    1) Scaricatevi da qua il nuovo kernal compatibile con l'olipad, ricordatevi che il nostro tablet è simile al Malata Zpad T2
    2) Cambiate nello zip scaricato il file boot.img con quello presente nella "Rom Cyanogenmod 7"
    3) Copiate il file zip che avete modificato nella memoria interna dell' olipad
    4) Entrate in Recovery
    5) Scegliete la voce: "install zip from sdcard" e poi "choose zip from sdcard"
    e poi selezionate il file zip per l' aggiornamento del Kernal
    6) Fate il Reboot, al riavvio dell' Olipad avete la possibilita di variare la freq. di funzionamneto fino 1.400GHZ
    7) Nel market cercate l' applicazioni (tipo: setcpu) per cambiare la Freq. di funzionamento.
    Avete Finito.
    Bug riscontrati: al riavvio può capitare il blocco del touchscreen.
    (soluzione: nella fase iniziale d'avvio toccare poco dopo il regolatore della luminosità in alto a destra sullo schermo).
    Ciao a Tutti.
  10. #419
    Senior Droid L'avatar di obaoba
    Messina
    Xiaomi RedMi note 3 Pro 32 gb
    Ringraziato 41 volte in 40 Posts
    Quindi, vediamo un pò, ti dicono che il download delle gapps non va e tu quoti il link che non funziona.
    Ora le cose sono 2, o ci hai presi per rincoglioniti, o ti sei "distratto" servirebbero anche a me, qualche anima pia?
    Device: Lg Optimus 2x OptiX Ics - Thl W200 Rom by Ludolo - Xiaomi RedMi Note 3 pro 32 Gb
  11. #420
    Htc explorer,S3 GT-I9300
    Qualcuno ha i link aggiornati perche ne va 1 su 3 di quelli nella guida....
    Leonarduk
LinkBacks (?)
  1. 02-09-12, 10:27
  2. 03-07-12, 11:46
  3. 23-06-12, 22:25
  4. 02-06-12, 17:46
  5. 12-05-12, 11:20
  6. 15-04-12, 01:11
  7. 25-03-12, 10:38
  8. 18-03-12, 13:22
  9. 13-03-12, 14:56
  10. 12-03-12, 18:08
  11. 10-03-12, 13:30
  12. 09-03-12, 10:06
  13. 02-03-12, 14:25
  14. 03-02-12, 16:09
  15. 31-01-12, 13:52
  16. 25-01-12, 00:34
  17. 25-01-12, 00:33
  18. 20-01-12, 10:30
  19. 03-01-12, 02:27
  20. 09-12-11, 11:34
