Processor: MT6750T octa-core Cortex A53 1.5GHz , ARM Mali-T860 MP2 680MHZ
OS: Android 7.0 Nougat
Display:
Size: 5.5 inch HD AMOLED LCD, Asahi Dragontrail screen glass, 720*1080 resolution
Touch: 5 points multi-touch
Color: Blue, Black, Gold
Cameras:
Primary: 13.0MP+2MP, 16MP interpolated,tru-tone LED flash light
Secondary: 8.0MP, 13MP interpolated,
Video record: 1080P video
Memory: 4GB RAM+64GB ROM, 64GB expandable
Network:
GSM: 850/900/1800/1900MHz;
WCDMA: 900/2100MHz;
4G FDD: B1/B3/B7/B8/B20
SIM card type: 2 nano SIM or 1 nano SIM+1 SD card;
Connectivity:
USB Port: Micro USB 5Pin
Ear jack: 3.5mm Samsung definition
WLAN: Support,802.11 a/b/g/n/,Hotspot
Bluetooth: V4.2
Sensors:
Front press fingerprint sensor/ Gravity sensor/ proximity sensor/ Light sensor/
gyroscope sensor/ geomagnetic sensor/notification LED
OTG: Yes
OTA: support
FM Radio: support
Dimensions: 156*77.8*10.7mm, 232.8g
Battery: 8000mAh, 9V/2A charger
