import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStreamWriter;
import java.net.HttpURLConnection;
import java.net.URL;
import java.net.URLEncoder;
import java.security.cert.X509Certificate;
import java.text.SimpleDateFormat;
import java.util.HashMap;
import java.util.Locale;
import java.util.Map;
import javax.net.ssl.HostnameVerifier;
import javax.net.ssl.HttpsURLConnection;
import javax.net.ssl.SSLContext;
import javax.net.ssl.SSLSession;
import javax.net.ssl.TrustManager;
import javax.net.ssl.X509TrustManager;
import android.util.Log;
import com.google.gson.Gson;
public class ServerProxy {
static {
TrustManager[] trustAllCerts = new TrustManager[] {
new X509TrustManager() {
public java.security.cert.X509Certificate[] getAcceptedIssuers() {
return null;
public void checkClientTrusted(X509Certificate[] certs, String authType) {
public void checkServerTrusted(X509Certificate[] certs, String authType) {
try {
SSLContext sc = SSLContext.getInstance("SSL");
sc.init(null, trustAllCerts, new java.security.SecureRandom());
HttpsURLConnection.setDefaultSSLSocketFactory(sc.g etSocketFactory());
} catch (Throwable t) {
HostnameVerifier allHostsValid = new HostnameVerifier() {
public boolean verify(String hostname, SSLSession session) {
return true;
HttpsURLConnection.setDefaultHostnameVerifier(allH ostsValid);
private static <T> T call(URL serverBaseUrl, String endpoint, Map<String, String> params, Class<T> responseClass) throws IOException {
T response = null;
URL url = new URL(serverBaseUrl, endpoint);
BufferedWriter writer = null;
BufferedReader reader = null;
try {
HttpURLConnection connection = (HttpURLConnection) url.openConnection();
connection.setRequestMethod("POST");
connection.setRequestProperty("Content-Type", "application/x-www-form-urlencoded");
connection.setConnectTimeout(10000);
connection.setReadTimeout(10000);
connection.setUseCaches(false);
connection.setDoInput(true);
connection.setDoOutput(true);
// Invia i parametri attraverso il writer.
writer = new BufferedWriter(new OutputStreamWriter(connection.getOutputStream()));
int paramCounter = 0;
for (Map.Entry<String, String> entry : params.entrySet()) {
if (paramCounter > 0) {
writer.write('&');
writer.write(URLEncoder.encode(entry.getKey(), "UTF-8"));
writer.write('=');
writer.write(URLEncoder.encode(entry.getValue(), "UTF-8"));
paramCounter++;
writer.flush();
writer.close();
writer = null;
// Legge la risposta del server.
reader = new BufferedReader(new InputStreamReader(connection.getInputStream()));
Gson gson = new Gson();
response = gson.fromJson(reader, responseClass);
reader.close();
reader = null;
} finally {
if (writer != null) {
try {
writer.close();
if (reader != null) {
try {
reader.close();
return response;
public static String register(URL serverBaseUrl, String phoneNumber, String deviceId) throws IOException {
Map<String, String> params = new HashMap<String, String>();
params.put("phone_number", phoneNumber);
params.put("device_type", "Android");
params.put("device_id", deviceId);
RegisterResponse response = call(serverBaseUrl, "register.php", params, RegisterResponse.class);
if (response.code != 0) {
throw new IOException("errore server: " + response.code + " " + response.description);
if (response.result == null || response.result.private_key == null) {
throw new IOException("errore server: risposta non valida");
return response.result.private_key;
public static void send(URL serverBaseUrl, String privateKey, String senderPhoneNumber, String recipientPhoneNumber, String message) throws IOException, UnknownRecipientException {
params.put("private_key", privateKey);
params.put("phone_number", senderPhoneNumber);
params.put("recipient", recipientPhoneNumber);
params.put("message", message);
SendResponse response = call(serverBaseUrl, "send.php", params, SendResponse.class);
if (response.code == 4) {
throw new UnknownRecipientException();
public static Message[] retrieve(URL serverBaseUrl, String privateKey, String phoneNumber) throws IOException {
RetrieveResponse response = call(serverBaseUrl, "retrieve.php", params, RetrieveResponse.class);
if (response.result == null || response.result.messages == null) {
return new Message[0];
int size = response.result.messages.length;
Message[] ret = new Message[size];
for (int i = 0; i < size; i++) {
ret[i] = new Message();
ret[i].id = response.result.messages[i].id;
ret[i].senderPhoneNumber = response.result.messages[i].sender;
ret[i].recipientPhoneNumber = response.result.messages[i].recipient;
ret[i].text = response.result.messages[i].message;
try {
ret[i].sentTimestamp = new SimpleDateFormat("yyyy/MM/dd HH:mm:ss Z", Locale.US).parse(response.result.messages[i].ts_sent).getTime();
} catch (Exception e) {
Log.w("freem", "formato timestamp non valido in " + response.result.messages[i].ts_sent, e);
ret[i].sentTimestamp = System.currentTimeMillis();
return ret;
private static abstract class Response {
public int code = -1;
public String description = null;
private static class RegisterResult {
public String private_key = null;
private static class RegisterResponse extends Response {
public RegisterResult result;
private static class SendResponse extends Response {
private static class RetrieveResult_Message {
public String id;
public String sender;
public String recipient;
public String message;
public String ts_sent;
private static class RetrieveResult {
public RetrieveResult_Message[] messages;
private static class RetrieveResponse extends Response {
public RetrieveResult result;
public static class UnknownRecipientException extends Exception {
private static final long serialVersionUID = 1L;
public static class Message {
public String id;
public String senderPhoneNumber;
public String recipientPhoneNumber;
public String text;
public long sentTimestamp;
