codice:
import android.app.LoaderManager;
import android.content.ContentValues;
import android.content.CursorLoader;
import android.content.Intent;
import android.content.Loader;
import android.database.Cursor;
import android.net.Uri;
import android.os.Bundle;
import android.support.annotation.Nullable;
import android.support.v4.app.Fragment;
import android.support.v4.app.FragmentActivity;
import android.support.v4.widget.SimpleCursorAdapter;
import android.text.format.Time;
import android.util.Log;
import android.view.ContextMenu;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuInflater;
import android.view.MenuItem;
import android.view.View;
import android.view.ViewGroup;
import android.widget.AdapterView;
import android.widget.EditText;
import android.widget.ListView;
import android.widget.Toast;
import java.util.ArrayList;
import java.util.List;
import ivano.android.com.ucanote.ivano.android.com.ucanote.db.Db;
import ivano.android.com.ucanote.ivano.android.com.ucanote.db.UcanContentProvider;
import ivano.android.com.ucanote.ivano.android.com.ucanote.db.UcanContract;
public class FragmentAsList extends Fragment implements View.OnCreateContextMenuListener,LoaderManager.LoaderCallbacks<Cursor> {
private SimpleCursorAdapter myCursorAdapter;
//brought out from OnCreateView, have to be in all the class
List<String> tasks = new ArrayList<String>();
ListView listView;
Time today = new Time(Time.getCurrentTimezone());
Db myDb;
EditText etTasks;
public FragmentAsList() {
super();
public void populateView() {
//TODO FIRSTclean the class and see if you have to get rid of the query in populate view()
getLoaderManager().initLoader(0, null, this);
// String[] projection ={UcanContract.Tasks._ID,UcanContract.Tasks.COLUMN_TASKS};
//Cursor cursor=getActivity().getContentResolver().query(UcanContentProvider.CONTENT_URI,projection,null,null,null);
String[] fromFieldNames = new String[]{UcanContract.Tasks._ID,UcanContract.Tasks.COLUMN_TASKS};
int[] toViewId = new int[]{R.id.text_v1,R.id.text_v2};
myCursorAdapter=new SimpleCursorAdapter(getActivity(),R.layout.textview_pretty_cool2_layout,null,fromFieldNames,toViewId,0);
listView.setAdapter(myCursorAdapter);
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
// Add this line in order for this fragment to handle menu events.
setHasOptionsMenu(true);
//open Database
myDb = new Db(getActivity());
myDb.open();
@Override
public String toString() {
return super.toString();
@Override
public void onCreateOptionsMenu(Menu menu, MenuInflater inflater) {
inflater.inflate(R.menu.menu_fragmentaslist, menu);
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// // Handle action bar item clicks here. The action bar will
// // automatically handle clicks on the Home/Up button, so long
// // as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
switch (id) {
case R.id.add:
Intent intent_comunicate = new Intent(getActivity(), DetailNote.class);
intent_comunicate.putExtra(getActivity().getPackageName(), "CIao Cipollino");
startActivityForResult(intent_comunicate, 123);
break;
case R.id.delete_all:
registerForContextMenu(listView);
getActivity().getContentResolver().delete(UcanContentProvider.CONTENT_URI, null, null);
populateView();
return super.onOptionsItemSelected(item);
@Override
public void onActivityResult(int requestCode, int resultCode, Intent data) {
super.onActivityResult(requestCode, resultCode, data);
if (requestCode == 123) {
String string = data.getExtras().getString(getActivity().getPackageName());
Log.d("FragmentAsList", "stringa dall altra activity: " + string);
Toast.makeText(getActivity(), string, Toast.LENGTH_LONG).show();
today.setToNow();
String timeCurrent = today.format("%Y-%m-%d %H:%M:%S");
ContentValues values = new ContentValues();
values.put(UcanContract.Tasks.COLUMN_TASKS, string);
getActivity().getContentResolver().insert(UcanContentProvider.BASE_CONTENT_URI, values);
// myDb.insertRow(string, timeCurrent, null, null);
//database query
populateView();
@Override
public View onCreateView(LayoutInflater inflater, @nullable ViewGroup container, @nullable Bundle savedInstanceState) {
View hiddenList = inflater.inflate(R.layout.fragment_as_list_layout, container, false);
listView = (ListView) hiddenList.findViewById(R.id.list_hidden);
populateView();
listView.setOnItemClickListener(new AdapterView.OnItemClickListener() {
@Override
public void onItemClick(AdapterView<?> parent, View view, int position, long id) {
Log.d("ivano.android.com.ucanote.FragmentAsList", "onItemClick (line 115): tocca posizione: " + position);
return hiddenList;
@Override
public void onCreateContextMenu(ContextMenu menu, View v, ContextMenu.ContextMenuInfo menuInfo) {
super.onCreateContextMenu(menu, v, menuInfo);
MenuInflater mi = getActivity().getMenuInflater();
mi.inflate(R.menu.context_menu, menu);
@Override
public boolean onContextItemSelected(MenuItem item) {
AdapterView.AdapterContextMenuInfo info = (AdapterView.AdapterContextMenuInfo) item.getMenuInfo();
int index = info.position;
Uri uri = Uri.parse(UcanContentProvider.CONTENT_URI + "/"
+ info.id);
String where = String.valueOf(info.id);
switch (item.getItemId()) {
case R.id.delete:
getActivity().getContentResolver().delete(uri, where, null);
populateView();
break;
case R.id.edit:
break;
case R.id.share:
break;
return super.onContextItemSelected(item);
@Override
public Loader<Cursor> onCreateLoader(int id, Bundle args) {
CursorLoader cl = new CursorLoader(getActivity(), UcanContentProvider.CONTENT_URI, projection, null, null, null);
return cl;
@Override
public void onLoadFinished(Loader<Cursor> loader, Cursor data) {
myCursorAdapter.swapCursor(data);
@Override
public void onLoaderReset(Loader<Cursor> loader) {
myCursorAdapter.swapCursor(null);
e la main class
