Pagina 5 di 7 primaprima ... 34567 ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 70
[FOTOGRAFIA] Full Screen Pic [FREE]
  1. #41
    Androidiano L'avatar di cb56
    Ringraziato 26 volte in 21 Posts
    Full Screen Pic Picture Viewer 4.7 è stato rilasciato ora
    Novità:
    • Added "Fast Pics Transition Effects" option
    Miglioramenti:
    • improved the effect on the image display
    • Improved Enlarged Pics Transition Effects
    • Improved Slide Show Transition Effects
    • Improved drag action to activate the Slide Show
    • Clear Folder History Confirm Message has been removed
    • Fixed move Pic when Pic's height < screen height
    • Fixed Swipe when a folder contains only one Pic
    • Minor bug fix
    Market Link: Full Screen Pic Lite
    cb56
    I'm hungry...may be foolish
    cb56 Android Development BLOG
    Full Screen Pic Picture Viewer 4.8 è stato rilasciato
    Novità:
    • Added "Status Bar Color" Option
    • Added Contest Menu "Jump to Top" & "Jump to Bottom"
    Miglioramenti:
    • Folders are Sorted by "Last View Pic" by default
    • Files are Sorted by "File Time Descending" by default
    • "Theme" Option replaced by "Background Color" Option
    • Graphical improvements
    • Fixed ScrollBar not visible with Lollipop
    • "Flat Title Bar and Black Splash Screen" Option has been removed
    • Minor bug fix
    cb56
  4. #43
    Full Screen Pic Picture Viewer 4.9 è stato rilasciato
    Novità:
    • Shortcuts to quickly activate many functions with long touch on a Pic
    • Persistent Quick Pic Info option to display Exif data while browsing the Pics
    • Jump to... Menu to quickly search for Pics by date or filename
    • Grid columns configurable
    • More Status Bar Color Options
    • Pics Background Color Option
    • Longh Touch on list Item Open Contest Menu
    Miglioramenti:
    • Thumbnails resolution improved
    • Performance improved
    • Minor bug fix
    cb56
  5. #44
    Full Screen Pic Picture Viewer 5.0 è stato rilasciato
    Novità:
    • Added "Jump To" Icon in App Title
    • Touch on Folder in the App Title now Open "Go To" Menu
    Miglioramenti:
    • Context menu revised
    • Delete File Function revised
    • Performance increased (some Lags has been removed)
    • Fixed Out of memory on old devices
    • Minor bug fix
    cb56
  6. #45
    Full Screen Pic Picture Viewer 5.1 è stato rilasciato
    Novità:
    • In the PRO version has been removed the message when Sharing Pics
    • Added Contest Menu "Share This Pic"
    cb56
  7. #46
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da julianbrown5181 Visualizza il messaggio
    Come hai fatto senza stirata.
    Abbiamo finito con i post inutili? Grazie.
    Smartphone:
  8. #47
    Full Screen Pic Picture Viewer 5.2 è stato rilasciato
    Novità:
    • Android 6.0 Marshmallow Update
    Miglioramenti:
    • Fixed Resize when Pic Scale is greater or equal to Screen Scale
    • Improved Font Size & Background Color of Jump to List
    • Improved Jump to List Positioning
    • Minor Graphical improvements
    • Minor bug fix
    cb56
  9. #48
    Full Screen Pic Picture Viewer 5.3 è stato rilasciato
    Miglioramenti:
    • Minor bug fix (no need to reesize message text & behavior)
    cb56
  10. #49
    Nov 2013
    N5 6 e 7, ONE S, TAB S8.4
    Ringraziato 308 volte in 268 Posts
    Quote Originariamente inviato da cb56 Visualizza il messaggio
    Miglioramenti:
    cb56
    Sbaglio o l'app è stata abbandonata? ho la pro e da mesi aspetto un update che la renda compatibile col nexus 6 ma niente di niente...
    X ringraziare chi ti è stato utile usa semplicemente il tasto THANKS a sinistra:basta 1 solo click sullo schermo contro 6 sulla tastiera per scrivere g r a z i e
  11. #50
    Quote Originariamente inviato da opt1imus Visualizza il messaggio
    ...poco tempo da dedicare all'App in questo periodo.
    Che problemi hai col Nexus 6?
    cb56
