Codice PHP:
#!/system/bin/sh
# enable zRAM script
# zRAM Swap Disk Size: 64MB(64*1024*1024)
disksize=67108864;
# Set Size to system
echo $disksize > /sys/block/zram0/disksize;
# Enable Swap (Need BusyBox installed)
busybox mkswap /dev/block/zram0;
busybox swapon /dev/block/zram0;
NTFS:
* Necessita del file "ntfs-3g". download here :ntfs-3g
* E' presente nel file zip .
Codice PHP:
Changelog :
Code:
29/10/2012
back to old ramdisk (TWRP 2.2.1) in order to fix tether issue
fix error in function "usleep_range" when compile kernel
modified LMK
add more governor & iosched
remove some Useless driver & tweak
remove zCache
Mega Update 01/11/2012: Release 1.0
Codice PHP:
01/11/2012
Added Aroma Installer
Added Usb OTG support<NOT WORK> so sory :(
Set swappiness to 15
Updated SIO to 2012 version and tweaked it
Jhash speed tweak
Implementation of SHA-1 and remove ARM SHA-1 routines
Ext4 disk write performance regression
Tweaked deadline scheduler a bit
Add a TINY_PREEMPT_RCU
Use TINY_PREEMPT_RCU to reduce memory footprint, and feel more smooth
Add tracing for TINY_RCU and TINY_PREEMPT_RCU
Priority boosting for TINY_PREEMPT_RCU
Tweaked writeback and cache for better battery life
scusate, ma cosa sono tutti questi codici?
non serve semplicemente flashare la recovery e poi fa tutto lui o si devono inserire da qualche parte, se sì dove??
