mkel91
Grazie a Frapeti per averla resa funzionante sul Galaxy Ace 2 JellyBean
Universal kernel flash tool
Cosa fa?
Puoi finalmente flashare kernel direttamente da un'applicazione, senza creare danni o usare terminali
Istruzioni:
- Premere "Check compatibility button"
- Selezione un kernel
- Flash
- Reboot
FAQ:
Incrementa il bin count? No
Devo avere i permessi di root? Certo, ovviamente
E' sicuro? certo, ha un calcolatore md5 in modo da non poter flashare kernel corrotti
Ho creato un softbrick flashando per sbagli un file mp3 (?) cosa faccio? Tranquillamente riflasha con odin e torna tutto funzionante
Device supportati:
GT-I9070 Jelly Bean
GT-I9070 Gingerbread
GT-I9070P Gingerbread
GT-I8160 Jelly Bean
Codice PHP:
INCREMENTAL CHANGELOG:
[[Update 1.09]
60% of the total source rebuilt cause of data loss w/out proper backup I could rebuilt the app but my signing keys are gone, so do not expect more updates via Play Store anymore until I fix it or upload a different and separated apk
Added support for Samsung Galaxy Ace II (GT-I8160) JB version
Added support for CoCore 5.0 and 5.1, D kernel for Ace II
Minor changes
[[Update 1.08]
Fixed bug that caused FC's on some unsuported devices
Added reboot recovery / download (may not work in some kernels)
Added support for the following kernels:
CoCore-E 4.0
CoCore-E 4.2 (CWM)
CoCore-E 4.2 (TWRP)
CoCore-P 1.0
[[Update 1.07]
Now the app checks if the user has root and busybox installed before going further.
Implemented dump report system to send useful device information if your device is not compatible. Post in the original XDA thread. (need testing)
(Please note that devices with an MTD partition table may require some aditional work that is not currently supported by this app at the moment)
Removed "Check compatibility button" as it's not really necessary.
SIRI-RC4
CoCore-E 3.9 Nightly
CoCore 4.1 Nightly
[Update 1.06c / 1.06b / 1.06]
[Update] Bug fixed (wrong error message shown)
[Update] Added support for SIRI-RC3 kernel
[Update] Minor fixes / cleanup
Fixed issue that prevented Gingerbread users to use the menu buttons. (not tested)
Minor fixes in the source.
CoCore-E 2.9 (Nightly)
CoCore-E 3.3
ThunderZap 4.1 + TWRP
ThunderZap 4.1 + CWM
SIRI-RC2 (Experimental update) - AKA "Battery.bin"
[Update 1.05]
Released on Google Play Store!
They are actually the same .apk that you can download in this thread, the paid one is exactly the same, just use it if you want to support my job in any way
FREE: https://play.google.com/store/apps/d...rapeti.ukflash
PAID: https://play.google.com/store/apps/d...i.ukflash_paid
Implementation of threads / asynchronous tasks (no more hangs while flashing / backing up)
UI Improvements
Stock LPY,LPZ and LQ4 JB kernels are now detected
Fixed issue that allowed users to press wrong buttons while flashing
Fixed issue that allowed unsupported devices to switch to backup mode
[Update 1.04b / 1.04]
Bug fixed: No more issues with sd card free space (I hope so )
New feature: Current kernel backup (press menu)
[Update 1.03b / 1.03]
Fixed bug that prevents gingerbread users to use the app - thanks buick1356 for testing on gb!
Added I9070P compatibility (not tested)
Logcat implementation
Detection of kernel compatibility and Android version
Detection of invalid file extensions
Added automatic detection for the following kernels:
CoCore-E 2.8 by cocafe (Jelly Bean)
OMEGA V2 (Jelly Bean)
CoCore 4.1 by cocafe (Gingerbread)
[Update 1.02]
Now working with gingerbread (you know what you flash, do not blame at me lol)
[Update 1.01]
Automagically detects common kernels if the MD5 checksum is correct.
Detected kernels:
ThunderZap 3.5 by Varun.chitre15
Siri RC2 by AdiPat
[Initial release 1.00]
It's working!
Grazie a lucasideas per l'idea!
Download::
Universal Kernel Flasher 1.0.9
